Bi-Xenon Fault
RobinA3
Well-Known Member
Gold Supporter
Cheshire
Recently my drivers side headlight has been flickering and now it turns off itself and comes up with 'dipped beam fault' on the DIS.
If i turn the lights off and then on again it fires up but then dies again pretty much straight away.
Anyone had the same issue?
I am dreading on having to spend stupid money for either a new control unit or a bulb!
what does vagcom say? I'm sure if you dont mind fleabay etc the bulbs are too bad, its the controller for Bi thats bit rarer & more pricey.
not had chance to vagcom it yet, hoping its the bulb but knowing luck it will be the control unit.
I had the exact same problem with my drivers light, and less often on my passangers. I changed both of the xwnon bulbs and hey presto problem solved. When i took the old ones out there was "crap" in the little gas chamber, which i beleive was causing the problem.
Euro car parts do the bulbs for about £70 each and they are genuine philipps ones.
Hope this helps!
Sounds like bulb to me mate, £50 set on ebay 6k & work no worries.
849
13
6
N8
