Results 1 to 12 of 12
    Aug 2010
    46
    ** HELP ** Audi A3 XENON HEADLIGHT
    I was wondering if anyone knows how i can go about installing bi-xenon headlights on my audi a3 2007 Sline.
    I have brought the bi-xenon headlights but there is a problem.
    The standard halegon headlight loom which is already in the car has 9 pins but the bi-xenon headlight requires a loom which has 11 pins. So the loom on the car doesnt fit the bi-xenon headlights.
    Has anyone converted standard halegon headlights to bi-xenon headlight and if so how they went about doing this?
    Many Thanks
    Pii
    Pii's Avatar
    London
    748
    I'm sure this quite a tricky task but hopefully someone will be able to offer more info.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    they arent plug and play even with an adater loom (youll get it from kufatec) you will need a rewire central convenience module light module and levelling sensors to get it all to work, then add the optional washer jets into the mix
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    v1raj's Avatar
    Apr 2009
    279
    Drop NHN a pm. He's the man for the job. (Well, for mine)
    2006 Audi A3 (8P)
    Spec - 2.0 TDI l DSG l Sprint Blue l Leather Interior l 18" RS6's | H&Rs | S3 Front | 6k Bi-Xenons | EMTuning DPF Delete Package
    Plans - BBS
    Aug 2010
    46
    Aug 2010
    46
    XENON ADAPTER
    Anyone know where i can get a adapter to convert halogen to xenon headlight for an audi a3 2007??
    pluves1's Avatar
    Dec 2008
    222
    I presume you got xenon headlights to fit onto your car?
    If you have then I believe you need a kit like this
    Auto-Leveling Headlights - Retrofit- Audi A3 8P/8PA/Cabrio [33790] - $488.66 : Kufatec USA, Inc., The #1 Supplier of OEM Volkswagen & Audi Retrofit Harnesses in the World
    As it says in description you also need to ensure you have headlight washers as well. According to stuff I've read this ain't an easy conversion but, I'm open to being corrected!
    Now
    MY10 BMW 335d Touring (Sapphire Black)
    MY10 S3 Sportback (Sprint Blue)
    Previously
    06 BMW 330d M Sport Touring Le Mans Blue with Black leather, Phone Prep
    Khufu's Avatar
    West coast of Scotland
    5,693
    Isn't the connector between standard xenon and halogen the same? I thought it was only the Bi-xenon/ASF that needed the adaptor (plus a lot more too)
    Aug 2010
    46
    Thaks PLUVES1, but that link is for a kit from halogen to bi-xenon.. whereas the headlights i have are xenon, and KHUFU the standard connector for halogen has 9 pins and doesn't fit the xenon. the xenon headlight requires a 10/11 pin adaptor
    The part number for the xenon headlight i have is: 8P0 941 003 AA
    Khufu's Avatar
    5,693
    AA rev are bi-xenon, thats why you need adaptors. You will also need at least a rev 8P0 907 279 K central electics module to code the car to accept bi-xenons. Sorry, your gonna have fun getting them to work.
    26,747
    Quote Originally Posted by khan_1212 View Post
    Dont need one, same 10 pin connector if its standard single vision xenons.
    Quote Originally Posted by Khufu View Post
    Yeap, 10 pin for halogen/xenon 14 pin for bixenon/adaptive
    Sorry you're wrong mate, as above & as Ewan has advised AA iirc are bixenon.
    F revision central electrics iirc is 23 byte, so is the lowest version needed for the proper coding of bixenons or you'll have issues guaranteed.
    26,747
    Khan, try to keep the xenon issue you have to one thread please mate as we will have info across many threads when you need it all in one mate, I will ask the mods to merge the 2 I've seen or if you could please as pointless having multiple for same discussion, thanks.
