Hi Mate just fill it to the maximum line the rest of the chamber is to allow foe expansion.I dont think it will have an adverse effect if its only a bit over. Hope this helps. Cheers
You can affect the heat transfer to the engine by over concentrating it, a few & is neither here nor there, but i wouldn't go 100% AF as the engine/water pump etc isn't designed to run like it.
