Volks AutosBadger5
Results 1 to 10 of 10
Thread: Tweeter (BOSE)
    Apr 2004
    1,139
    Tweeter (BOSE)
    I had the A pillar trim swapped a while ago by the dealer when my car was in warranty because it made noises sometimes (annoyance noises) and i've been convinced ever since that the tweeter is no longer working - is there a really simple way to check?
    I've tried fading the music to the front right, reducing bass and middle to lowest point, but still can't tell whether there is any sound coming from the tweeter to be honest.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    You can remove the speaker grill from the door card easily, unscrew the speaker out and disconnect the front speaker.
    Then go into your settings on your head unit and fade everything to the side of the suspected broken tweeter. If you dont hear anything then it is a dud.
    If it is a dud, I am not sure what Audi's policy is on Audio parts like speakers. They might consider them as "wear and tare" and not cover them under warrenty. Something I have not experienced but since they removed your A pillar, you could argue that it was damaged by them.
    Apr 2004
    1,139
    Sounds good. How easy is it to get the speaker out of the door/grill off etc? Do you have to remove the door card?
    Pii
    Pii's Avatar
    London
    748
    Why not just turn up the volume, open the door wide, stand outside the car and lean your ears as close to the tweeter as possible?
    You should be able to hear the tweeter sound a lot better this way.
    Make sense?
    Apr 2004
    1,139
    Makes perfect sense - i just wanted to do it in a way which was more subtle - suspect i may look like a bit of a pillock doing this!
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Do it in the dark and no one will see!!! When you do it, turn the treble to max on the headunit to make the tweeters work harder...
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Pii
    Pii's Avatar
    London
    748
    Lol - put a cloth in your left hand then and make it seem like your cleaning the dash or something
    Apr 2009
    Florida (previously Liverpool)
    655
    ...Plus, set the balance and fader so the sound comes ONLY from that speaker...
    Simples.
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Just go to the far side of the speaker grill, closest to the engine and just give it a light tug - should easily come out.
    I do not think you have to take the door card off but if you do, there are 3 torque screws on the underside (T15 IIRC), 3 behind the door trim (just get an edge and pull) and one in where the door handle is. Give the door card a wee tug from the bottom and it should easily come off. Maybe have your window down as well as the top of the door card is tucked into the top of the door frame!
    Pii
    Pii's Avatar
    London
    748
    Ok I just tried something that might help you.
    - play music
    - open door wide
    - Stand close the the pillar
    - Cup the tweeter with your left hand
    - You should hear a distinct change in the sound being projected from the tweeter
    Either do this is take Boydies advice but my suggestion takes 5 seconds.
    Good Luck.
