EM TuningMonster Motorsport
Results 1 to 25 of 25
    181
    Trying to fit a cold air feed to my ITG help!!
    Im trying to fit some 100mm ducting from the fog light grill area up to below the filter head of my induction kit and falling at the first hurdle!
    How do you get the fog light grill off?
    I have misplaced my owners manual and so can't look in there, and I've looked for clips that may release the grill but can't find them!
    Any help is much appreciated, this is so frustrating because I've had the ducting for days now and I just want to get it put in along with the heat resistant tape
    Cheers and I promise a quick write up with pictures if someone will tell me how to crack open the grill!
    gone: 2008 S3 sprint blue, buckets, optics, go-faster mods.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,775
    Its easy mate - just pull around the edge of the fog light surround.
    So say you are facing the passenger fog light. Pull at the side of the fog surround (around the fog light) closest to the edge of the bumper (from the right hand side) then just wiggle it a bit. Mine come out easily.
    181
    Got it fitted
    I've decided to remove the fog light and place the ducting behind thatas it seemed to be the most direct way to feed the air up to the filter- anyway got a few pics to upload will do that later! and maybe a better vid of the exhaust!
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    Lookin forward to write up and pics. Gonna do this to mine shortly.
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    Boydie's Avatar
    Boycie
    Dec 2006
    4,775
    Did you have to remove the fog light? could you not just have position it to the right of it where the big gap is in the plastic?
    warren_S3's Avatar
    Oct 2007
    6,186
    Quote Originally Posted by Boydie View Post
    Managed to leave the fog light in on mine: http://www.audi-sport.net/vb/showthr...909#post982909
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    181
    So here I was ready to start on fitting my DIY cold air feed to just below the ITG filter head, I grabbed some tools out of the garage but to be honest all you really need tool wise is a phillips screwdriver to undo to jubilee clips on the intake & a stanley blade(or similar) to cut the ducting to size.
    First thing I done was pop off the fog light surround grill, which took a bit of effort as my fingers were too big to fit in the gaps to tug it off, I persisted to tug at the four corner of the grill and eventually one of the corners popped out which then made it very easy to pop out the rest of the grill- don't worry about snapping the plastic it is pretty damn tough!
    This picture shows the ducting I have fed in which took a bit of effort due to the fact it's 100mm and not 76mm which would have fit a lot easier!
    Next thing I done was undo the last pipe on the intake which is connected to the filter head and lifted it out to enable me to access the area where I would be feeding the ducting into
    This is the view I had looking into the engine bay trying to locate where I've pushed the ducting into and where I'd be pulling it up to below where the filter head sits
    You can see here that 100mm is probably a bit large for the space given but I ran with it anyway, it just took a bit of force to manouvre into place but one good thing is it wont really need much fixing to keep it in place as it's so tight!
    I then trimmed the ducting at the fog light end to size and re-attached the grill.
    To make it more secure I attached a bit of foam where there was a small gap and used waterproof tape on the other side just to make sure the ducting wouldn't go anywhere, it felt pretty snug so I doubt the tape or foam is really needed, I just fitted it to make sure and so far after a few runs in the car it hasn't budged!
    I decided to remove the fog light on the other side as well just to make the car look even on the front, it actually looks all right I think, quite sporty!
    I also decided to give the heatshield from my ITG a trim because it is simply too large for the space give and I reckon it would eventually rip anyway if left as it is, I didn't get a picture of this but it's only trimming a bit of foam with a stanley around the metal part so nothing exciting really but it does make a positive difference to the fitment!
    Back to the cold air feed, I've not really had the car out long enough or driven it hard enough to notice any difference and I doubt you would notice a massive difference from the cabin anyway but it's giving me peace of mind that there is a better feed of cold air going to the filter head than there used to be through the panel gap and this can only be a good thing!
    Next mods I've got on the list now are: Buy a VF Engineering intake and fit that (LOL) as I'm fairly sure I'm going for a GIAC extreme plus map and apparently this is what I need due to the fact is a full 3" onto the turbo, but annoying as I'd only just fitted the ITG for chirsts sake! But I'd rather use the hardware GIAC/Statler recommend with the software than try something else and get a disappontment.
    Take out some of the aluminium finish interior part and skin them in carbon fibre, see http://www.carbonmods.co.uk/Products...CMCFSK300.aspx
    Then get the thing down to sheffield and get it mapped!
    After that I'll look and the addition of an intercooler, then its onto handling and braking which should be fun (expensive )
    Anyway apologies if you were expecting a detailed write-up I was just wanting to show a couple of pictures and a bit of text to show what I'd done which might help someone else if they want to do the same or something similar without my mistakes haha
    Craig
    181
    In the 5th picture the ducting has not been pulled out and cut to size at the other end and that is why it is all coiled up, once it was done you could see daylight through it from the engine bay!
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    you have removed your fog lights for no reason! You could have just cut a hole in the solid black plastic part nearer to the middle like I have and most others have..doh !
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    181
    Not for no reason, as you just said you have had to cut a hole to make your system work, I've just removed the fog which can go back in very easily with no permanent changes.
    I understand your way of doing it but I kinda like the way it looks without the fogs and I'm reasonably happy with the outcome!
    No just the one ITG that I planned on selling whilst it was still in the box as I was going to sell the car, circumstances have changed and I can now keep the car longer than I thought so I fitted it a couple of weeks ago and now I've been advised I'd be better off with the VF Engineering intake for the software I want installed so it's up for sale again and I'm on the lookout for a VF!
    Am I right in thinking the VF is 285? or is that for a KO3?
    akash_sky1's Avatar
    1,209
    Quote Originally Posted by craig32 View Post
    yeah I just read your post RE GIAC and the Extreme K04 map. forgot about that intake/ maf issue. I cant remember of the top of me head but check out Regal's price there UK's other main GIAC tuners,they import all the VF parts and sell em
    Boydie's Avatar
    Boycie
    Dec 2006
    4,775
    I don't see how you had to remove your foglights - there is a perfectly good gap on the passenger side fog light which allows cold air in anyway and as demonstrated by warren, it shows that it has been done.
    181
    I'll tell you why I had to remove the fog lights....
    Because I wanted to,theres not really any other reason apart from that.
    I read Warrens thread closely and I agree with pretty much everything he has done, but to be honest I fancied doing something different. Period
    P.s leave my crappy attempt at a cold air feed alone Boydie you bully
    Boydie's Avatar
    Boycie
    Dec 2006
    4,775
    LOL I am not getting at you at all - Boydie the keyboard warrior!
    Just don't understand why you wanted to remove the foglight as it is part of the S package.
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    its well easy im going to go buy this ducting today i think.. where from? plumbers merchants? B&Q?? ill fit it when i do my engine cover next week...
    S
    181
    haha I'm only kidding, I seen a pic of a phantom black S3 on here that had them removed and for some reason I really liked it and because it worked with my installation I just thought I'd give it a go
    The fog's don't make our cars "S" you can get fogs on any A3, things like the aluminium wing mirrors I would never change though!
    Quote Originally Posted by S3RYE View Post
    I tried pretty much all the merchants and they never had the right stuff, neither did my local b&q!
    I got mine from a company called Auto Silicone Hoses if you look at the link below theres a few different size/material options and they deliver quite quick!
    http://www.autosiliconehoses.com/
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    guys i was cleaning my car last night thinking about this mod and i was thinking... would the intake create a vacuum and suck water up the ducting? i mean im just thinking about big puddles, very wet conditions??
    craig - would you advise 100mm ducting or should i go for something slightly narrower? 90,95mm??
    and does the vent come out in the same fashion on the 8p3???
    S
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    boydie, im not sure how else i can do it? to the left of the fog is like a duct that goes somewhere into the unknown (cant get my arm down it to see where it goes? where else could you put the ducting? cheers
    S
    JamesS4cab's Avatar
    Mar 2008
    1,091
    I have an ITG question while we are on this subject as well.
    I fitted mine this weekend but really dont see where the cold air comes from if i have the metal backed foam in place that came with it. The original cold air feed now feeds into the wrong side of the barrier and the cone is sat on the otherside so I really dont get where its supposed to be getting a cold feed from unless you add this ducting. I am thinking i might do this, but wanted to see what anyone else thought?
    Thanks.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    181
    Ryan I had the same problem!!! and that is why I ran it from the fog light!
    I have now got it into the area next to the foglight but the bit of plastic you are talking about is ducting which seems to lead the air through to....I'm not exactly sure where lol
    I basically spent ages messing around trying to get it off and came to the conclusion you pretty much have to smash it a bit then saw it off, if I come to sell the car I guess I'd just order another one and fit it again!
    It's funny as I started this thread about my ITG and now it's a VF enigineering intake, still same process though.
    181
    [QUOTE=JamesS4cab;1046148]I have an ITG question while we are on this subject as well.
    Yeah a few folk are of the opinion that the small panel gap that the air gets through towards the filter is too small to deliver enough air especially for the large size of the filter head.
    I agreed with this and that was the main reason I set about fitting the cold air feed!
    A simple inexpensive mod that can can only do good for the induction.
    On the subject of water ingress Warren pointed out during his ITG development session that Andy the guy from ITG said that it wasn't a major issue provided some common sense was applied, i.e not roaring up behind cars at high speed when they have water spraying from the rear and avoiding deep standing water which petrol cars should avoid anyway!!
    May 2009
    131
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    emeraldguy... care to share how you managed this? and what you did with the air duct to the left of the fog light?
    S
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    and mines an Evoms... i just really want this mod done... it must be so much better for intake temps...
    S
    May 2009
    131
    I have a A3 so the S3 bumper was installed without the blockoff plate. I just ran the pipe from the airbox down to the grill.
