Sky InsuranceChris Nott
Results 1 to 11 of 11
Thread: DMF OR SMF?
    123
    Lightbulb DMF OR SMF?
    Hiya guys,
    Its time for me to replace my clutch and flywheeel
    I been thinking and doing sum research and found that theres a conversion kit to convert to a single mass flywheel which means no more replacing the flywheel only the CLUTCH.
    Has anyone converted their a3 TDI to a single mass conversion?
    Just looking for some info on the topic and im preety sure this is the place to find it.
    Im based in West Midlands near Birmingham, does anyone no any cheap places to get the parts?
    Cheerz
    Javz
    123
    Can anyone shed any light?
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,765
    I would go for a standard DMF and SACHS uprated clutch if you are wanting to change
    devonmikeyboy on here is very knowledgeable regarding TDI tuning - his A3 Quattro has 330bhp and is running a SMF as far as I know.
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    SMF rattle like hell on diesel cars and the lighter you go the worse it is. VAG changed the design of the DMF from the PD140 onwards so a lot few flywheels tend to wear out. My DMF lasted 20,000 miles while running 300+bhp. Unless you are going big power i wouldn`t bother even thinking of it to be honest.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    Yes on diesels heard they make a hell of a racket! And with the low red-line and much narrower power band, dont think there's as much benefit with a SMF anyway is there? Even modded diesels with be riding more on a surge of mid range torque then ultimate top end and the diesel's tall gearing will keep get the best of out of this, so a very quicky revving engine not neccesarily as important on a diesel.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    123
    The reason why i came to lookin at the SMF is this link....
    http://www.eurocarparts.com/ecp/c/Au...cc6fc10e3&SCON
    The Solid Flywheel Conversion Kit has been developed to replace the Dual Mass Flywheel which suffers from such high failure rates. Because the Dual Mass is being replaced by a single Mass Flywheel you can expect greater durability and when the clutch is due for replacement there is no need to change the Flywheel so savings in the long term can be vast. Each kit will come with solid Flywheel, Clutch kit, bolts & fork where needed. Some vehicles that Conversion kits are fitted to also require a concentric slave cylinder which needs to be purchased separately.
    123
    Iv read that the SMF's end up with a lot of noise and vibration, however ive read that a number of people have converted and have no problems, other than the slight vibrations/noise which is hardly noticeable.?
    akash_sky1's Avatar
    1,209
    the main drawbacks really are NVH- ( noise vibration & harshness). Also with a lighened flywheel the engine will LOOSE rpms just as easily as gaining rpms, so it would affect how the car behaves on the motorway quite notiecable ie engine brake much quicker.
    Not sure if I'd want one on a diesel due to the noise- one person on UK MKIVs said his 1.9tdi sounded like a tractor with an SMF one. given that the 1.9tdi ALREADY sounds like a tractor I can imagine the noise was pretty bad.
    Longevity wise there are much better though as long fitted with a clutch designed for one.
    Mar 2008
    Bradford, WY
    788
    I have a sachs clutch kit and smf on my 2.0tdi. Yes its noisey on idle but when in gear like most of the time there no chatter. Acceleration is quicker and harder! If you can put up with the chatter on idle then I'd defo reccomend it.
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    123
    how bad is this noise on idle? cuz im 100% sure my flywheel has gne however the car is still running and working, the noise on idle is horrible its as if the flywheel plates are clashing together?
    if thats what the SMF is going to sound like id be happier with the DMF.
    Feb 2007
    1,257
    That is the noise you will hear. The DMF takes the slack and vibration out of the clutch/gearbox. With no DMF everything rattles when the gearbox is not driving forward or backward with the clutch peddle up.
