[ QUOTE ]
Sorry to bring up an old thread.
I'm seriously considering this mod as there are several glovebox cd-changers for sale on german e-bay at present for next to no money.
Clicky 1
Clicky 2
For those of you that have done this mod, how easy would you rate it on a scale of 1 Haynes spanners to 5? (I reckon my limit is about 2!).
Also, did anyone suffer any rattling or other annoyances afterwards? I would hate to damage my car. /ubbthreads/images/graemlins/mad.gif
Japper says the new glovebox is £138. I presume this is just the inside shelf bit? What happens with the glove box light and the passenger air bag on / off switch?
Thanks in advance. /ubbthreads/images/graemlins/beerchug.gif
[/ QUOTE ]
adamr,
On a scale of 1-5, I would put it at around 2 max. The £138 is for the complete glovebox including lid as it's a complete unit. You also need a CD changer cable. Dont know cost of cable as I got it with CD changer off e-bay.
Here goes from memory.
Undo 6 or 7 bolts ( 10mm hex head ) 2 underneath in footwell, 2 under front lip when lid open, 1 at back of compartment, and 2 under plastic cover on side, when passenger door is open.
Support the glovebox with your knee's while you undo the last bolts. The glovebox now pulls away and you need to undo the connectors to the light and airbag deactivation switch. You also need to remove the aluminium trim opposite catch as this is not part of £138. It just pulls towards the drivers side of the car.
Next you need to cut out the hole for the airbag switch, it is marked but needs cutting. If you use , carefully, a stanley knife to lightly score all around the front edge a couple of times. Then you give it a good push with your thumb and it pops through. Any bits left can be sorted with knife. Remove the switch and light from existing glovebox and fit into new one ( clip in position )
Now using correct keys, remove stereo and the connector. Follow the given instructions for inserting correct coloured wires into existing connector block. Feed other end of cable through to glovebox area. Replace stereo.
Refit in reverse order, connecting wires to light and airbag switch at the same time.
Total time around 1 hour.
If you need any more info or get stuck while doing the mod, PM me.
