Chris NottMonster Motorsport
Results 1 to 19 of 19
    Mar 2010
    13
    What size tyres should i go for? 19x8.5 ET45
    Hey guyz,
    finally got around to being able to get some new wheels so am going for 19x8.5 ET45 size on my 06 A3 S-Line.
    Im planning on dropping on 35mm H&R springs ( cant afford coilys at the mo ).
    Will i get any rubbing issues if i use 235/35/19? Does anyone run this size?
    any help much appreciated.
    kj
    locost47's Avatar
    Aug 2009
    Lurgan
    121
    Im Running 19x8.0 et42 with 235/35/19 tyres also on 35mm H&R springs and day to day driving with no rear passengers there is zero rubbing, with a full load of passengers it does rub on the back over bumps but remove the top screw on the rear bumper lip to reduce this. The rubbing only occurs because of the tyre touching the screw and the felt material that lines the inside of the arch so don't worry about it making any contact with metal bodywork as it won't.
    Votex Front Lip | 19" RS4 Anthracite | S3 Rear Valance | S3 Pedals | Votex Spoiler | H&R 35MM | LED Sidelights | Alcantara DTM Steering Wheel | S2000 Locost race car !
    RAPS3's Avatar
    Moo Moo Land
    1,040
    I think your going to struggle with a 8.5" rim on ET45 with a 235 to be honest.
    I know people do run 19 x 8 ET45 with a 235 tyre, but it depends on tyre choice also.
    I cant say I've heard of anyone with a 8.5" rim running this size, in fact you may need to drop down to a 215.
    I'm sure someone more knowledgable will be along shortly (N8)
    Paul R
    S3 Sportback - Sprint, Buckets, Bose, Rain & light, Alu rails, Piano trim, FT Warning, Bluetooth prep
    S3's now sold - roll on the Golf MK1 Project
    Mar 2010
    13
    cheers for the replies so far... is there a difference between the clearances on the 3 door and 5 door cars? I've found someone running that size but his is a 5 door...
    RAPS3's Avatar
    Moo Moo Land
    1,040
    I've found when looking around and trying to sort out the issues I had with rubbing that the sportback suffers more rubbing issues than the 3 dr.
    You can remove the screw on the 3 dr and it makes a difference, however on the sportback makes no difference at all.
    See the photos below - of the issue I had - on reflection I think that mine was actually catching on the felt inner wheel liner and not on the bumper itself, but I couldnt be doing with any rubbing at all so dropped down to a 215 instead of running a 225 tyre, not ideal if your a foot to the floor driver all the time, bt a compromise I was willing to take.
    Paul R
    Mar 2010
    13
    woah... close lol Oh man jus saw that the springs come in 2 options.. - Front Axle Weight upto 1020 kg - Front Axle Weight from 1021 kg what is this about?
    May 2010
    2,502
    just to ask a similar question...
    i'm thinking of fitting 19x8.5J ET42s. what clearance issues am i gonna have with 8P2 S-Line suspension, and what tyres would i need?
    cheers in advance guys, and sorry for hijacking!!
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    215s for the win
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Mar 2010
    13
    Quote Originally Posted by sub39h View Post
    that's even more doubtful than mine! lol unless you planning on running 215's ???
    May 2010
    2,502
    Thing is i've heard of ppl running that set up with 235s and no rubbing. I was wondering how that was possible. I don't really like the stretched rubber look. Was wanting OEM plus all the way so for 8.5J 235 would be about right
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Go with 225s and 8.5 J and if u get rubbing its tough sh1t I suppose haha
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,767
    I have 235/35/19 on my 19x8.5's but you can get away with 215/225
    If lowering your car, I would opt of the 215's since you have a lower offset!
    Mar 2010
    13
    Quote Originally Posted by Boydie View Post
    i think il order 225/35/19 just to be sure and avoid any rubbing issues What offset do you have?
    Does anyone have a A3 56 plate 2.0 Tdi S-Line? I'm trying to find out what my front axle weight is but cant find it anywhere.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Is yours DSG kreative?
    Boydie's Avatar
    Boycie
    Dec 2006
    4,767
    My offset is et50 and they are genuine BBS CH. I have it lowered 25mm on h&r springs and previously lowered to the tyre on coilovers in my TDI A3 with no rubbing issues!
    Mar 2010
    13
    Quote Originally Posted by N8 View Post
    na mate 6 speed manual
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    K no worries.
    RAPS3's Avatar
    Moo Moo Land
    1,040
    I think Boydie can get away with this due to the the ET being 50 and not lower.
    As you can see in my pic above your talking millimetres from catching to not catching.
    Paul R
    Mar 2010
    13
    Quote Originally Posted by RAPS3 View Post
    ye im thinking better to be safe than sorry. Ive ordered 225's now
    Will i need a full alignment after changing the springs to H&R 35mm drop? Im assuming so...?
