Sky InsuranceEM Tuning
Results 1 to 10 of 10
    PTTM's Avatar
    Pedal to the Metal!!!
    Mar 2008
    Tewkesbury
    85
    Brake upgrade help needed ASAP!
    Gents your expertise on brakes is required again!
    I have tried to get all info by searching other threads but i still need a little more info.
    I have a 2006 a3 2.0tdi 3dr and desperately need the entire brake setup replacing as im at 101,000 miles and have only replaced the pads since buying 3 years ago at 16,000 miles.
    I have read that the R32 / S3 / 3.2 brake setups are 'almost' identical.
    So for me to get that setup and get a garage to fit them labour only I would need to provide them with the following:
    - Brake discs
    - Pads
    - Calipers
    - Carriers
    - Brake Lines
    Where would you recommend I start looking and would I just ask if they have the parts for the R32 / S3 / 3.2 braking system?
    Do I need the setup from the same year as my car (2006)?
    As the brakes aren't intended for my car, will it take considerably longer for the garage to fit the above larger brakes rather than replace like for like?
    Obviously if I cant acquire the above would some grooved discs and ebc redstuff pads be a considerable improvement on the stock brakes, which frankly suck!
    Any other things I should take into consideration?
    Thanks again chaps!
    May 2010
    60
    Your options are as you stated above with possibly the splash guards as well, ebay should provide these used for 200-250ish. or if you change your carriers for the 312mm ones, then the disks and pads (splash guards maybe) you can go to 312mm setup. this should be cheaper although when I was looking I ended up finding the r32 ones cheap first.
    2.0TDI DSG S-Line in Red
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Quote Originally Posted by PTTM View Post
    EBC stuff is the devil! Stay clear! Black Diamond Combi discs and Ferodo DS2500 pads and you'll be sorted!
    I usually get my stuff from these guys -
    http://www.europerformance.co.uk/pag...category=brkes
    Front -
    Black Diamond Combi 288 x 25mm - 135
    Ferodo DS2500 Pads - 129
    Rear -
    Black Diamond Combi 255 x 10mm - 140
    Black Diamond Predator Pads - 38
    Thats the set up i run on my 306 Rallye track car, as good a brake as you'll get for the standard size without going 2-piece etc.
    Black Diamond Combi
    PTTM's Avatar
    Mar 2008
    Tewkesbury
    85
    Thanks Cimic / Crunchie!
    I heard that EBC can be troublesome from the lads at GFS Parts. Although some people swear by them on here!!! So ill give them a miss, even though I have greenstuff on my fronts atm :s
    Will the Black Diamonds combi be worth the wedge?
    Still wouldnt mind the nice big discs that you get off the 3.2Q on my tdi.....ah well beggars cant be choosers
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    If you defo want to go BIG then i think this is your best option.
    Same as R32 & A3 V6.(or at least the fronts are)
    You can upgrade discs to Tarox if required.
    I thought the Black Diamonds were quite cheap, pads not so.
    http://www.awesome-gti.co.uk/product...13789&xSec=150
    Mar 2008
    Bradford, WY
    788
    why not go crazy and get some s3 brembos 380mm http://www.fr-rtuning-shop.co.uk/ind...productId=1697 if only I had a 500bhp hothatch
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    I'm not too clued up with the whold std master cylinder thing, might be wasting your time without doing it?
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Quote Originally Posted by navnayyar View Post
    3k!!!!!!!!!!!!!! Ha, no danger! They do look the dangles tho!!!
    PTTM's Avatar
    Mar 2008
    Tewkesbury
    85
    For 3,000 I would want a parachute that deploys from the rear of my car in emergencies!
    Bit overkill for a 170hp diesel me thinks although would definately look the dogs.
    PTTM's Avatar
    Mar 2008
    Tewkesbury
    85
    Choices, Choices!!!! Im sticking with your first idea crunchie! Black Diamond combi etc! Thanks everyone
