Sky InsuranceEM Tuning
    j50sho's Avatar
    May 2010
    33
    a3 2.0tdi blip power
    hi guys, currently on-going problem which im getting help with from nigel... my car blips in power in all gears every so often, fault code threw up a maf problem which i replaced, the replacement did help but i still have the blip normally around the 2k rev point, one thing i noticed is when i first start the car in first gear when i reach about 1800rpm the car chugs (if thats the right word) .. got no fault codes up now .
    should i check for leaks or possible fuel contamination?
    Mar 2008
    Bradford, WY
    788
    have you checked map/thrust sensor?
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    j50sho's Avatar
    May 2010
    33
    replaced the maf mate.
    one thing ive also noticed, when i had it remapped the guy showed me in the gears it rev'd to 4000rpm, now it only reaches 3000... dont know if that is saying anything
    Mar 2008
    Bradford, WY
    788
    Quote Originally Posted by j50sho View Post
    im not talking about the maf, map/thrust sensor is different is common fault in these tdi's
    V16
    V16's Avatar
    214
    where is the map/thrust sensor located? i replaced my maf but still a slight jerk now then, unplugged the maf and it drove like new!
    Black A3 S-line 2.0TDi
    Mods: Hybrid Turbo - Custom Exhaust - Weitec Coilovers - Tints - Gloss Black Optics Grill - Led Number Plate Lights - Led Interior Lights - S3 Mirrors - Retro Fitted Arm Rest - 09 rear lights - R8 Oil Cap - Phillips Diamond Vision Lights
