JMB RetrofitsAH Fabrications
Thread: Stance help?
    Jul 2010
    Stance help?
    ok, first of all im new to this so this is most likely to be a repost but here is goes. i have a 3 door a3 2010 sport.
    im thinking 19's for it but dont want to get coilovers, just springs. how low would i need to go to pull it off? i like lm's, heillo's and BLQ rotiforms. Thanks in advance
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    With LM's in my opinion you would need the decked look
    I have 19" BBS CH on my S3 and only lowered 25mm on H&R springs which is nearly as low as my A3 TDI was on the same rims!
    Check out the rims thread at the top of the page!
    Jul 2010
    Can't get the link here on my phone you think 40 mm springs would do the trick.? I'm just really not sure think I'd like to get haillos. But not sure if 40 mm's would pull it off. What you think??
    Jul 2010
    Any pics of your old one? Did you have coilies on it? I just want to see how low it would be with 40 mm springs.
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    I wouldnt put 40mm springs with standard shocks- the dampers will be too compressed and the ride bouncy as hell, and they will wear out quickly.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Jul 2010
    Think I'd have to go for shortened shocks too?
