Volks AutosAH Fabrications
Page 1 of 3 123 LastLast
Results 1 to 40 of 90
    Jul 2010
    Audi S3 8L N249 valve bypass - how to?
    Hi,
    Could someone help me bypass the N249 valve on an Audi S3, year 2001, 1.8T, 210 HP quattro, AMK engine?
    Bellow there`s a picture of the engine with the valve. Please explain, if possible using the picture, what do I have to do, witch hoses do I have to move. I've searched the web, but I haven't found a guide for this specific engine.
    Thank you!
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    Disconnect the hose from the divertor valve nr rip out all the crap. leave the N249 connected with no hoses on and hide it down by the coil packs then just run a new hose from the bottom of the inlet manifold to the divertor valve
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Oct 2009
    150
    What is the reason for doing this?
    Westy's Avatar
    Dec 2008
    17,263
    Read the link matey.
    It basically stops the ECU from being able to open the DV when on throttle which can reduce performance.
    S3 Build Thread
    Sep 2009
    Essex
    2,366
    and also eliminates the potential one million leaks you can get with the n249
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Quote Originally Posted by Matt82 View Post
    ...although he has introduced one by using a Forge Split-R ;P
    <tuffty/>
    Sep 2009
    Essex
    2,366
    one step forward, two...
    Oct 2009
    150
    So does everyone do this and is it worthwhile?
    Westy's Avatar
    Dec 2008
    17,263
    If you do a search I posted up some VAGCOM results where i was holding another 2 pound of boost due to this mod. I did before and after logs and it is definitely worth it. It also sharpens up the throttle response quite a bit.
    S3 Build Thread
    Sep 2009
    Essex
    2,366
    i did it because i couldnt be arsed to go over the n279 mess and check for leaks, and i could tell it gave the ECU control over my fun, started to rave about it on the board and it turns out everyone does it haha
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Is the N279 the gubbins that monitors air on cold start? Because if so I'm ripping this **** out as well.
    Sep 2009
    Essex
    2,366
    i think youre thinking about the secondary air doo dah
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    N249 bypass definitely helped on mine. DV noise got alot louder too but that's with my BMC kit aswell.
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    Oct 2009
    150
    does it put extra strain on the turbo though? surely they wouldnt put the n249 in for no reason
    Jul 2010
    99
    same as above - wont this effect engine/turbo?
    Jul 2010
    99
    thanks
    funnyclub's Avatar
    Apr 2010
    Ireland
    65
    Me thinks I need to do this
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    663
    its on my list too after the remap! i liiike the feedbacks
    Westy's Avatar
    Dec 2008
    17,263
    Did anyone actually read the link I posted above?
    It wont put any extra strain on the turbo as this mod doesn't increase boost. The N249 valve is controlled by the ECU and uses pressure stored in the vac reservoir (Black Box in the pic above) to open the DV if necessary as an engine safty feature. Reasons for the ECU to open the DV are:
    - Triggering of traction control. If you've got ESP and you've really tried to beans it through a roundabout in the wet you'll know what I mean. The ECU detects you're well out of shape, opens the DV and you feel the power and car bog down, nasty!
    - Boost spikes. The ECU can detect a spike or surge of boost and will open the DV to protect the engine but at the end of the day there are other devices in place to detect issues, such as ignition retardment, so nothing to worry about.
    In summary all old turbo cars with a DV opperate in this way (without the N249) and Audi just stuck the N249 syste on as an extra safety feature as they were releasing a 210/225 hatchback that would be driven by old ladies and mums doing the shopping.
    S3 Build Thread
    Jul 2010
    And where would the N112 valve be located on the engine from the first post picture? Under the vacum chamber? Because, if I got in right, I have to use the T piece, the right side goes to the BOV and the left one to the N112. Am I getting it right?
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by Luciano View Post
    The N112 isn't in that pic, its underneath the plastic panel that holds the dipstick tube. You might not have the N112 valve as they weren't on the newer engines. Mine's a BAM and they didn't have them.
    So if you dont have the N112 all you need to do is use a 3/4mm joiner or get a new piece of silicone hose and plum together the DV hose to the one that goes to the front nipple of the inlet manifold, done.
    S3 Build Thread
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    IIRC, your engine is AMK? and so doesnt have secondary air injection? So also doesent have the N112??
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Cookstein View Post
    APY has the N112 valve, the AMK and BAM don't as they don't have SAI.
    Homer Simpson
    Madeley's Avatar
    Jun 2010
    Telford
    125
    what car is the APY engine for?
    Netherlands
    33
    Quote Originally Posted by Madeley View Post
    1999-2000 S3
  28. #27
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Thanks, l got a APY in mine! l keep reading about AMK,BAM, l thought l got the wrong engine in the old girl(2000 S3).
    Good luck in the world cup Stig.
  29. #28
    Jul 2010
    Job done! It's true that my AMK engine doesn't have the N112 valve, so I' simply conected a 4mm silicon hose from the intake manifold to teh BOV. I left the N249 valve electricaly conected and...that's it!
  30. #29
    Jul 2010
    99
    hi luciano, you noticed a big difference?
  31. #30
    Oct 2009
    150
    what inside diameter silicon hose did you use mate and where did you get it? is it worth doing?
  32. #31
    Jul 2010
    There is a difference, not spectacular, but you can feel it and the BOV sound is better...a little bit turbo lag reduced.
    The diameter of the silicon hose is 4 mm.
    This where you can get it. http://www.forgemotorsport.com/conte...product=FMVT4B
  33. #32
    Sep 2009
    Essex
    2,366
    3mm id has always made a perfect seal on a vac nipple ime
  34. #33
    Dazboss's Avatar
    Like A Thristy Dingo ;)
    Jul 2010
    366
    Sorry for another question.
    Can i bypass this one mine. It's engine code AJQ ?
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
  35. #34
    Jul 2010
    99
    Thanks luciano, im doing this now >>>>> runs off to do this now lol
    2001 AMK S3, Black, Lowered, 18" RS4 Diamond cut and Black Polished Alloys
  36. #35
    Jul 2010
    99
    i just attempted this and ended up snapping the nipple under the manifold
    please please when doing this bypass, use a straight connector piece or something if you cant take the hose clamp off the manifold nipple, i wish i thought of that, now im stuck (see my post)
  37. #36
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    Just for clarification which is the better route to go down then 3 or 4mm id tubing?
    Edit: How much tubing is required roughly if replacing it all?
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
  38. #37
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by thorsy22 View Post
    Either really, they are both a sufficiently good fit.
    Homer Simpson
  39. #38
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    i got 3 meters and was plenty
  40. #39
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    Sweet cheers guys, for the sake of a tenner figured might as well replace all the tired old hoses.
    TT pedals
    N249 bypass
  41. #40
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    Do I need jubilee clips it or are the push fit barbs/nipples sufficient?
    TT pedals
    N249 bypass
