Badger5Chris Nott
Results 1 to 11 of 11
    Aug 2009
    Kent
    70
    ABS and Tracion control light on all the time.
    I have the ABS light and traction control light on all the time now, but my brake lights are working ...
    Can anyone help ?
    Traction control is turned off and ABS is switched off too...
    Mar 2010
    Durham NE
    578
    You will nedd to have it pluged into vagcom (vcds) to scan for fault codes and go from there mate regardless of your brake lights working bud.
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    664
    speed sensors...yaw sensor...acceleration sensor
    Jun 2003
    World of my own
    9,813
    You can switch off ABS?
    Alex Turner
    Mar 2010
    Durham NE
    578
    I think what he meant was with the abs/esp light on the abs/esp is not working....dont guess,put diagnostics on there to find out the fault as one will be logged.
    James
    Silver Audi 8L S3
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    664
    for sure you have to log vag.
    just thinking what it "might" be
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    My moneys on either the lateral or longitudinal acceleration sensors, but as has been said the only way to know is to get it scanned for faults.
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    I had this/got this, steering angle sensor, brake light switch and ABS controller all needed replacing.
    Really need to get it on VAGCOM to confirm what it is tho.
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
    Feb 2009
    Telford
    31
    i also had this problem, after hooking it up to vagcom it turned out to be a wheel speed/abs sensor
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    have you removed your steering wheel ?
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Aug 2009
    Kent
    70
    Wow .. that's a load of replys , it all sounded quite possible , to answer the questions
    No not had the wheel off , no cant turn ABS on I only have a button for traction control , I have been pressing it to turn traction control off .... and turning it back on as it goes way too quickly round bends for the poor little 16" wheels ! before this happened the traction control was cutting in way to early on right hand bends , I had thought it was after a 4 wheel alignment 12 months ago but not sure ...I have a feeling this was the steering angle sensor ..hope its not the abs controller as that sounds expensive !! as the brake lights work I guess its not the brake switch, anyone in the west midlands with vagcom able to run a scan for me , my MAC wont run vagcom ;o(
