Volks AutosAH Fabrications
Results 1 to 23 of 23
    May 2010
    colchester
    223
    Forge 007p taken off for forge split r were can i sell the forge 007p best place ?
    Taken off my forge 007p for a split r,whats the best way to set up the split are,people slag this off but how can it be crap like people say when there about 50 more ? thanks alot...
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    They chatter alot apparently. Meant to do something like 20 clicks clockwise or something. Not too sure, but dont sell your 007p just yet untill you figure if you like the split r.
    May 2010
    colchester
    223
    Is there a thread on this yet how to set up? or has any body eles have one of thease ?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Have you put your split R in yet?
    May 2010
    colchester
    223
    no mate why's that dont wanna put it on till i no how to set it up ...
    S3KO4's Avatar
    Aug 2009
    London
    850
    20 clicks from closed position, I would recommend using the blanking cap to stop the extra air escaping, otherwise you are droping the boost, therefore it cts like a leak. I would buy your 007p if you like
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    May 2010
    colchester
    223
    i want to have a bit of noise due to me swapping....and why would people buy em if it acts like a link and i dont no how much my 007p worth
    Sep 2009
    Essex
    2,366
    Quote Originally Posted by L3WJX View Post
    haha what if they put a couple extra zeros in the price. surely then it would be the bestest ?
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    people would probably buy them for the noise it makes when you come of the throttle and are happy to pay the extra?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    is there any compromise in power from running this split r does it make any difference or is it all about the noise????
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    both valves essentially do the same thing, they protect the turbo by venting the boost when the throttle is closed and lets the turbo deaccelerate without the backflow.
    The normal diverter valve just diverts the boost back to the intake side of the turbo. The split diverter valve diverts some air back to the intake side of the turb and some air it just vents to the atmosphere (your engine bay) and you can hear it do this.
    Alex S3 AMK
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    so it would seem to me that the oo7 may be better???? power wise???
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    ...mmm, i think power wise there isnt any difference between the two valves, the boost isnt being used when the valves are operating because the throttle is closed.
    When you come off the throttle the throttle plate closes and you boost from the turbo hits the closed valve and (if you dont have a DV) bounces back to the turbo and flows through the turbo in the wrong direction this is what makes that fluttering noise as the tubine stalls against the backflowing air.
    The diverter valve stops this from happening. When you come off the throttle it creates a vacum in the intake manifold, this vacum opens the diverter valve and vents the boost from the charge pipe back into the intake side of the turbo.
    Alex S3 AMK
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    i would opt for the normal one though. For one, as already said the split R is 50 more, why would you want to spend that much on a noise. And two, but more important, the normal DV recirculates the air back into the system so that the ECU still knows how much air is in the system
    Alex S3 AMK
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    i think you compromise a bit of performance and more lag when you use the split R valve.
    Tons of threads about this matter.
    I cant really use words to explain how...but you loose some power.
    more expensive doesnt mean better...for a 1.8T the best dv is the forge 007 and the bailey recirculating valve.
    for other cars the forge split r would be maybe better
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    and if you want to sell it , post in the classified section with a good price and im sure someone will pick it up
    May 2010
    colchester
    223
    how much should put it up for ?
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    789
    5 ill have it lol
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    i bought my 007 off ebay for 40 in good condition. My old one i got for 35 off ebay. so around that i guess.
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    May 2010
    colchester
    223
    i will stick ebay tonight then thanks guys
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    789
    Does the 007P make any noise at all?????
    May 2010
    colchester
    223
    yep a little matey not alot but got a nice little note i just want a little bit loulder ...
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    789
    does it make more sound than standard
