Sky InsuranceAH Fabrications
Results 1 to 10 of 10
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Help with VAGCOM codes
    Morning all,
    I would like to say a_big_thanks_to_pns2007_for_taking_the_time_to_plu g_it_in
    Heres_the_results
    First_time_he_pluged_it_in-
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    Address 01: Engine Labels: None
    Part No: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 66565
    VCID: 3874D6E5323B
    WAUZZZ8LZ1A039621 AUZ7Z0Y1613559
    8 Faults Found:
    17939 - Camshaft Timing Adjustment: Open Circuit
    P1531 - 35-00 - -
    17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P1200 - 35-10 - - - Intermittent
    16487 - Mass Air Flow Sensor (G70): Signal too High
    P0103 - 35-10 - - - Intermittent
    16804 - Catalyst System; Bank 1: Efficiency Below Threshold
    P0420 - 35-00 - -
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    17695 - Boost Pressure Control Valve (N249): Open Circuit
    P1287 - 35-10 - - - Intermittent
    16711 - Knock Sensor 1 (G61): Signal too Low
    P0327 - 35-00 - -
    16716 - Knock Sensor 2 (G66): Signal too Low
    P0332 - 35-00 - -
    Readiness: 0000 0100
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 15178
    Shop #: WSC 00628
    VCID: 2F66EDB9C775
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01365 - Lock/Unlock Switch; Interior
    29-00 - Short to Ground
    00991 - Interior Lights
    28-00 - Short to Plus
    00956 - Key 2
    09-00 - Adaptation Limit Surpassed
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0C4DE854A2B
    3 Faults Found:
    01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
    27-00 - Implausible Signal
    01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
    01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
    35-00 - -
    Fourth_time_after_clearing_codes-
    VIN: WAUZZZ8LZ1A039621
    Coding: 10710
    Shop #: WSC 66565
    VCID: 3874D6E5323B
    1 Fault Found:
    P1531 - 35-00 - -
    Readiness: 0110 0101
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 06435
    VCID: 3E78C0FD101F
    2 Faults Found:
    01423 - Lateral Acceleration Sensor (G200)
    57-00 - Electric Circuit Failure
    00778 - Steering Angle Sensor (G85)
    62-00 - No or Incorrect Adjustment
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8L0 820 043 J
    Component: A3 KLIMAAUTOMAT 0101
    Coding: 00041
    Shop #: WSC 06435
    VCID: 2F66EDB9C775
    No fault code found.
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 4008
    Coding: 01104
    Shop #: WSC 06435
    VCID: 458AAF1175C9
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 L
    Component: AB-KOMBIINSTR. VDO D12
    Coding: 01442
    Shop #: WSC 00628
    VCID: 3C7CCAF50603
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    VCID: 1F461D79B7D5
    Coding: 15178
    Shop #: WSC 00628
    VCID: 2F66EDB9C775
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0C4DE854A2B
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00014
    Shop #: WSC 06435
    VCID: E5CACF915509
    The_one_that_stands_out_is_17939 - Camshaft Timing Adjustment: Open Circuit.
    I've_read_it_could_be_the_a_relay_or_sensor,any_on e_shed_any_light_on_this?
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Can_anyone_help,l_can't_find_out_what_this_code_me ans_its_not_even_on_the_ross_tecs_site.
    P1531 - 35-00 - -
    26,716
    Yes he is a very helpful chap.
    Alot of engine errors there, alarm ones do popup & are minor overall.
    It would signify a broken connection, you need to check the wiring schematics & as you say any associated relays/fuses.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    oh dear, never seen so many errors, you are about to spend some cash
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    pns2007's Avatar
    Nov 2008
    626
    Hi Dave (Madeley) Hope you get it sorted. A lot of error codes but we managed to clear quite a few.
    One fast car there mate, had to change my underpants after the demo lol
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    Madeley's Avatar
    Jun 2010
    Telford
    125
    I'll give you a update this weekend neil, thanks for your comments people.
    Madeley's Avatar
    Jun 2010
    Telford
    125
    P1531 - 35-00 - -
    Found the problem, l got the wrong engine in her.
    My car is a 2000 face lift s3 2001 model that should have a AMK(says in the boot) but some one has put apy engine in.
    What l need to no is could i fit a vvt actuator to a apy engine, or can l get it mapped out? as its built into the apy.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    apy ecu maybe?
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Would it be a Audi job to change the ecu and program it to the car, would be nice just to drop a apy ecu straight in.
    26,716
    Uh yeah audi would be 1 port of call, immo etc has to be setup for it aswell I should think.
