Morning all,
I would like to say a_big_thanks_to_pns2007_for_taking_the_time_to_plug_it_in
Heres_the_results
First_time_he_pluged_it_in-
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine Labels: None
Part No: 8N0 906 018 J
Component: 1.8L R4/5VT 0004
Coding: 10710
Shop #: WSC 66565
VCID: 3874D6E5323B
WAUZZZ8LZ1A039621 AUZ7Z0Y1613559
8 Faults Found:
17939 - Camshaft Timing Adjustment: Open Circuit
P1531 - 35-00 - -
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-10 - - - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17695 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-10 - - - Intermittent
16711 - Knock Sensor 1 (G61): Signal too Low
P0327 - 35-00 - -
16716 - Knock Sensor 2 (G66): Signal too Low
P0332 - 35-00 - -
Readiness: 0000 0100
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 00628
VCID: 2F66EDB9C775
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
VCID: E0C4DE854A2B
3 Faults Found:
01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
27-00 - Implausible Signal
01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
Fourth_time_after_clearing_codes-
VIN: WAUZZZ8LZ1A039621
Coding: 10710
Shop #: WSC 66565
VCID: 3874D6E5323B
1 Fault Found:
P1531 - 35-00 - -
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 06435
VCID: 3E78C0FD101F
2 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
57-00 - Electric Circuit Failure
00778 - Steering Angle Sensor (G85)
62-00 - No or Incorrect Adjustment
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 J
Component: A3 KLIMAAUTOMAT 0101
Coding: 00041
Shop #: WSC 06435
VCID: 2F66EDB9C775
No fault code found.
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 4008
Coding: 01104
Shop #: WSC 06435
VCID: 458AAF1175C9
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 L
Component: AB-KOMBIINSTR. VDO D12
Coding: 01442
Shop #: WSC 00628
VCID: 3C7CCAF50603
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F461D79B7D5
Coding: 15178
Shop #: WSC 00628
VCID: 2F66EDB9C775
Coding: 00001
Shop #: WSC 00000
VCID: E0C4DE854A2B
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00014
Shop #: WSC 06435
VCID: E5CACF915509
The_one_that_stands_out_is_17939 - Camshaft Timing Adjustment: Open Circuit.
I've_read_it_could_be_the_a_relay_or_sensor,any_one_shed_any_light_on_this?
Heres_the_results
Coding: 10710
Shop #: WSC 66565
VCID: 3874D6E5323B
8 Faults Found:
P1531 - 35-00 - -
P0420 - 35-00 - -
P0327 - 35-00 - -
P0332 - 35-00 - -
Coding: 15178
Shop #: WSC 00628
VCID: 2F66EDB9C775
9 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
VCID: E0C4DE854A2B
3 Faults Found:
35-00 - -
Coding: 10710
Shop #: WSC 66565
VCID: 3874D6E5323B
1 Fault Found:
P1531 - 35-00 - -
Coding: 18448
Shop #: WSC 06435
VCID: 3E78C0FD101F
2 Faults Found:
Coding: 00041
Shop #: WSC 06435
VCID: 2F66EDB9C775
Coding: 01104
Shop #: WSC 06435
VCID: 458AAF1175C9
Coding: 01442
Shop #: WSC 00628
VCID: 3C7CCAF50603
VCID: 1F461D79B7D5
Coding: 15178
Shop #: WSC 00628
VCID: 2F66EDB9C775
Coding: 00001
Shop #: WSC 00000
VCID: E0C4DE854A2B
Coding: 00014
Shop #: WSC 06435
VCID: E5CACF915509
