Volks AutosAH Fabrications
    Jun 2010
    21
    weird buzzing electrical sound when i cancel indicators?
    Hi all.
    When I cancel the indicators on my a3 tdi 2002, I sometimes get a weird buzzing sound which seems to come from the hazard warning switch? This seems to stop if I put on my hazards but comes back when I put them off.
    Its also not all the time.
    Any ideas?
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    Dodgy Hazard switch IMO, I had exactly the same symptoms, a few days later the indicators started to work intermittently. Get a new switch from the stealers (28), replace switch and your buzzing problem should go away.
    It's a common fault on these cars, along with dodgy temp senders, broken window regulator clips, clutch pedals breaking, vacuum hoses disintegrating........
    Imteyaz.
    Purple Princess's Avatar
    Jun 2008
    Button moon with mr spoon and gang
    1,026
    ^^^^ yup I had the same. It's a very easy fix good luck
    Follow us on Facebook-Stacey-Byzan Photography-
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Mine does this as well, but only since I changed the relay to a new one...strange, I'll just keep an eye on it and see how it goes.
    devan's Avatar
    Jun 2010
    117
    I also had this, but it seems to have stopped doing it now since i had Cruise Control installed... maybe it was to do with the indicator stalk in my case??
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    I think it only happens if you've not quite fully cancelled (i.e the switch is half way).
    Current: RenaultSport Clio 172
    Previous: 2001 ('51) S3 Quattro
    Previous: 2001 E46 M3 Coupe
    Previous: 2001 Civic Type R
