Badger5AH Fabrications
Results 1 to 13 of 13
Thread: Rear washer jet
    G60DAN's Avatar
    Cornwall
    321
    Rear washer jet
    Hello all,
    Just hoping that someone may be able to help me.
    My rear washer jet has stopped working. It is not the jet, and its not the rusting out problem with the motor, the pump is working so I am LOST!!!.
    I have pulled the pipe off the motor but I am still not getting any water to the screen but the reservior is going down so it is going somewhere!
    Are there any joins in the pipe, and which side does the pipe run down?
    All help welcomed.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Is the passenger side of car wet, under the engine bay?
    G60DAN's Avatar
    Cornwall
    321
    I don't know will go and have a look
    G60DAN's Avatar
    Cornwall
    321
    Well give that man a prize so what is it then
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    remove the air filter box there is a trunking that goes up to the bulkhead inside there is a joint for the washer hose will be disconnected
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    The washer jet is fed by a pipe that runs through some black truncking behind the airbox, its a little push fit fitting that will have come undone, pop the black plastic cover off, shove the fitting back together and either leave it or wrap some eletrical tape round it to hold it together better, simples.
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    I have a similar problem, but it's not the connection in the pipe under the airbox, my rear washer squirts washer fluid, but only about 1-2 inches at best up the screen, I have checked the nozzel jet for blockages and all is clear. if it helps it takes about 10 seconds before fluid apears when first using the washer, I can't see any leaks but I'm open to any suggestions. Could it just be a pump not giving full pressure??
    Thanks in advance
    Nige
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    G60DAN's Avatar
    Cornwall
    321
    Thanks all will get to it right now.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Quote Originally Posted by sportquattro View Post
    Thanks in advance
    Nige
    Mine used to do the same.
    Inside the actual motor will have rusted and the washer jet pipe will have corroded, will still work just like yours is, you need to buy a new motor, i got one of a mk4 golf for about 20, although my wiper now sits on the right side of the back window instead of the left.
    Any mk4 based car motor should fit.
    Sep 2009
    741
    Hi, thanks for the tip, probably a daft question I'm assuming you mean the rear wiper motor as opposed to a pump motor in the reservoire
    Nige
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Yes mate i mean a whole new wiper motor.
    So what's the most likely thing when there is no water coming out but you can hear the pump. Does the nozzle block up usually?
    1.8tplym's Avatar
    Mar 2009
    Plymouth
    49
    http://www.audi-sport.net/vb/showthr...ht=rear+washer
    Pictures of how to repair the pipe
    the pipe does block easily. especially if you use carp screen wash and dont dilute enough. it took me about ten minutes of spraying with clean water and using a needle to unblock the jet before it freed up. now it fires further than a super soaker!!!! (anyone remember those?!)
    A3 1.8T Sport - K & N Panel Filter
