Chris NottJMB Retrofits
    kachnak's Avatar
    Sala, Slovakia
    117
    Question disconnected lambda sensor
    Hello,
    I do not have problems with my lambda sensor, but this lamda sensor is mounted on exhaust and cable from this sensor is disconnected.
    VAG do not say any problem about lambda sensor.
    Some people says that motor without lambda sensor is running in emergency mode or fuel consumption can be very high.
    What is your opinion about this?
    Thank you.
    S3 1999 154kw APY
    Audi S3 1.8T 154kw 210hp APY 1999
    GET LOW, NO MATTER HOW!
    S3KO4's Avatar
    Aug 2009
    London
    850
    Sounds like you might have a modified exhaust for a BAM ratherthan an APY and your engine has only one sensor on the DP. the disconected one is there just to blank that extra hole.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
