Badger5AH Fabrications
Results 1 to 14 of 14
    Dec 2009
    Wolverhampton
    21
    Brake Warning Light Suddenly Appears
    Hi Guys,
    just a quick one,
    When i turned on my a3 this morning and looked at the dash as normal, pulled off the drive and as soon as i looked bk down again my brake warning light kept flashing red on me!
    i need to change a pad or 2 and didnt think nothing of it!
    so i turned on the radio, only to hear the radio cut out and an intermitant beeping from the radio...in time with the flashing red brake warning light!
    checked the fluid and all seems to be fine!
    ive checked all the brake bulbs etc and ive only just changed the brake light switch, so im a little bit confoosed!
    HELP would be much appriciated.
    Jamesdownthepub
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    At risk of stating the obvious the fact that you say you need to change a pad or two is a good clue, sounds like the low pad warning is doing just what its supposed to do, new pads should sort it nicely.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Sounds like your front pads need replacing, the warning light will come on way in advance, but always worth having a visual check just in case.
    Dec 2009
    Wolverhampton
    21
    cheers for that...
    going back to another problem now that seems to be happening with the stereo...with intermitant beeping!
    its obiously a factory standard!
    when im driving along the radio just cuts out on some stations to a beeping that gets louder and louder...
    anybody else experianced this?
    jamesdownthepuv
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    hmm mine does this but then goes off and doesnt come back for ages then doesnt do it anymore strange. i had new brakes done all round a few months ago so cant be that... for me at least
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Dec 2009
    Wolverhampton
    21
    well after changing the rear pads and disks last week, im still getting this constant flashing of my brake warning light...the fluid seems fine...
    i am missing a disk retaining screw could this be it???
    any ideas?
    regards
    jamesdownthepub
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    No It won't be the disc retaining screw i'm missing two on mine and i don't get the warning light. have to connected the warning cable on the pads?
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by jamesdownthepub View Post
    any ideas?
    Orange warning light is brake pads - and that only counts for the front pads. Rear pads DO NOT have a pad wear sensor.
    See this link: http://net.jasonpearce.com/chronicle/audiwarnings.html
    Red means fault in braking system - most likely to be ABS related. Get it looked at. Brakes are somewhat important.
    Homer Simpson
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    If its a flashing red exclaimation mark, and three loud beeps on start up or shortly after (when you start moving) the abs system has a fault. It needs to be scanned to know for sure, but could be one of the many sensors or even the controller itself gone Pete Tong!
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Sounds like its the ABS sensor. Mine did the same and it turns the ABS had come totaly off. Weird one.
    Audi A3 1.8 Turbo, Wietec Ultra GT 40mm kit, 3" Full Custom Stainless Steel Exhaust, Custom Code stage 1 remap, 17" RS4 Alloys, Whiteline ARB
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    vagcom scan
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Dec 2009
    Wolverhampton
    21
    this red light is flashing constant however...my abs light is on all the time! ive got a mate with the snap on equip and its a rear wheel speed sensor but i didnt think it could affect the brake warning light coming on?
    no beeping on start however ive got an original audi stereo and sometimes the stereo cuts off and starts an ascending beeping...keeps gettin louder and louder...i end up turning it off and back on again. is this something linked?
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    or clean the connections/fuses on the battery
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    Any of the sensors associated with the abs system failing will bring up the big red exclaimation mark as the system won't be able to process the data so it will get reported as a malfunction.
    Not sure about the stereo issue being linked though.
    TT pedals
    N249 bypass
