g60leigh
Hi guys, I have had a search for help on this but not sure what I find is the same as my problem.
as with any noise it's pretty hard to describe but hope you can help
I have a singing / whaling noise coming from the rear of my S3
it sounds metallic but like a thin metal, sounds a bit like something rubbing against a body panel. it gets louder and higher pitched the faster I go but does not seem to be directly related to the speed. it does not go off when I press the brakes.
I have changed the rear discs and pads recently and have checked the heat shields around the exhaust and cannot see or feel anything loose.
has anyone else had this??
Thanks for the help
Thanks for the help
