Results 1 to 18 of 18
Thread: Oil usage.
    May 2010
    151
    Oil usage.
    Hi there , my s3 has done 112k , I'm trying to keep on top of my oil . Last Monday I checked it and it was rather low so I topped it up to just below the raised section on the dipstick , today I have just looked and it has gone down to about half the scale :s . Is this normal on this milage ? . There doesn't seem to be any puddles so it must be using it .
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    seams a bit quick how many miles do you do a day?
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    May 2010
    151
    I've done around 350 miles since the top up , some of that wad with a heavy right foot but mostly round town driving .
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    Could be a few things.
    Have you checked the expansion tank to see if oil is in there? Also take one of the upper boost hoses off and see if there covered in oil, it's normal for them to have a thin film over them due to the PCV system, you dont want them soaked though.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    As much as i don't like to make assumtions, last time i had that it was my turbo feeding oil directly into the exhaust. She didn't seem to smoke at all, but used a litre or so per 1k miles.
    Once i changed the turbo,all was fine
    There are so mnay ways for oil to go down, leaks, blocked breather raising the crankcase pressure, rings gone, valve stem seals gone, strainer blockage casusing excess turbo shaft wear causing excess comsumtion..... on and on
    May 2010
    151
    As odd as it sounds I had a massive crack in the pcv pipe that always splits had a fat off crack in it and was covered in oil , I've replaced that hose as of sat , do you recon this could have any play in the matter ?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    Quote Originally Posted by cawsey20 View Post
    Not to lose as much oil as your saying. Have you checked your exhaust like mark said to see it its caked up?
    May 2010
    151
    I have just looked yes it's black and sooty but aren't all cars normally ? .
    May 2010
    151
    My mate was following me also and as I put my foot down to overtake a lorry aparently he could smell an Eggy smell ? Could this be joined in any way? .
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    I mean oily residue?
    May 2010
    151
    No it all seems sooty and dry ?
    S3 Paul's Avatar
    Oct 2006
    2,764
    The eggy smell would be the cat getting very hot... either from heavy foot work or because its covered in oil and having a problem doing its job,
    Its a pain to work out where its going to be honest... My car started to use oil and then started to smoke when nailed. The general view was "its the mileage mate" I decided then to build a forged and solid new engine... new turbo the lot.
    After all this was done i took the head of the old engine... a stem seal had split and come off. So i spent 3500 and it was a rubber seal costing 80p from audi.
    The BEST way to tell if its the turbo or not is to undo the turbo to downpipe nuts. move it over slightly amd have a look/ feel inside. it should be slightly sooty but wet (oily) means its time for a new blower... hybrid maybe??
    Noggy Blue 2001 S3
    May 2010
    151
    Back to this subject , went to gti int yesterday , did a few runs and she is pulling fine surely if turbo was dying I'd notice it ? Also didn't see any smoke all day . I did about 500 miles all in and have used about 1 cm or so , is this majorly excessive still
    S3 Paul's Avatar
    Oct 2006
    2,764
    1cm on the dipstick??!
    If thats the case YES that is alot if it isnt making a nasty brown mark on the drive way.
    Noggy Blue 2001 S3
    May 2010
    151
    Sorry I lied it has used half a cm just under I just measured it , so 500 miles half a cm . Still excessive for 113k ?
    27,072
    Yeah I was at Inters, which colour car as saw a fair few derv's with black smoke bellowing out.
    I mean if you're hammering it everywhere & you have worn parts then it would be a fair assumption it will use more than norm.
    But, you do need to get to the bottom of the excess use or the problem could lead to much bigger issues & alot more money.
    May 2010
    151
    Ok mate , I'm not using the loud peddle all the time most of the time I'm just poodling to work reserving fuel . That's my fear that it will turn into an issue I'm going to have a ganders underneith now so ..
    May 2010
    151
    It's an s3 by the way mate
