EM TuningChris Nott
Results 1 to 11 of 11
    117
    Questions about parts (with pics)
    Hi guys.
    I did some brief work on my a3 last weekend and came across a few things that I'd like to ask about...
    Firstly, what is the flat plastic object that sits over one of the spark plugs? - See picture.
    I noticed a gap in the air intake pipe (see picture). Is this normal?!
    Finally, I replaced the water temp sensor (shown below), in an attempt to remove VAGCOM error code 17704 (Error in Mapped Cooling System (usually temp Sensor or Thermostat)). After doing so, the code remains. Do I need to clear the error to see if I have actually fixed it?
    Thanks!
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    The flat bit on top of the plugs is a vacuum chamber...... see threads on N249 removal and this will delte this and improve your dump valve response....to the detriment of overboosting
    the gap im unsure of, although id guess the MAF is off a different model if the gap goes all the way through
    and the code would need clearing though vagcom....simple enough to do if you buy a 10 lead off the bay
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    The gap isnt a gap....the seal on the MAF is further into the airbox. Dont worry about it.
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    117
    Thanks for the info guys. I ran VAGCOM when I got home from work and cleaned the codes. I took it for a spin and it felt really smooth and pulled well. Will re-check for codes tomorrow.
    1 final question on part identification...
    What is this, and should it be sticking out as much as it is?
    There is a ticking sound coming from it (or somewhere right by it). It doesn't seem to want to be pushed in more...
    Dazboss's Avatar
    Like A Thristy Dingo ;)
    Jul 2010
    366
    I noticed mine gives off a tick the little bugger, i think its a carbon chamber that reuses fuel. Im prob wrong though.
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
    76
    mine clicks as well.
    Madeley's Avatar
    Jun 2010
    Telford
    125
    I asked a Audi teck about this he said "ticking is good, you will hear it now and again"
    Dazboss's Avatar
    Jul 2010
    366
    Quote Originally Posted by Madeley View Post
    Did he say what it is though ?
    c_dog's Avatar
    Apr 2008
    Sussex
    99
    I was concerned about this and did some research, turn out it is omsething to do with charcol burning
    2001 A3 1.8T TQS
    1998 A8 2.8 Auto
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Its the charcoal collection chamber, and will, and is supposed to tick.
    It captures fuel vapors and prevents them from escaping to the atmosphere and then stores the fumes and recycles them to the fuel tank or engine intake for combustion as needed.
    The long and short of it is that it helps to protect the environment and improve fuel economy, allegedly.
    Annoying though it can be, ignore it. It's fine.
    Homer Simpson
    Biggied's Avatar
    They called him mellow yellow.
    Feb 2006
    Scotland
    202
    The last pic you showed is the vent pipe from the fuel tank to the charcoal filter & its quite normal for it to stick up like that. Also your temp sensor fault code for "mapped cooling" is usually related to a temp sensor built into an electronic thermostat housing, the sensor you have replaced is the G62 which usually puts up a differant code.
    Ewan.
    210hp 8L S3 quattro.
