fault code!! please help
spencerdale
NULL
hi, i fitted my coilovers yesterday and now my traction control light wont go off, i code read it on vag come and i got this....... steering angle sensor. is this linked? i tried to remove fault be kept coming back,
no i haven't, should i get it done now then? how come i cant clear the code? cheers dale
Depends what the fault code associated with it is (00778 iirc is for steering angle sensor and should have another number underneath it), if its intermittent signal then probably needs replacing. If its it out range or something similar then get the wheel alignment done and re-calibrate the sensor and should be OK.
