Monster MotorsportVolks Autos
Thread: Hesitation
    Oct 2008
    14
    Unhappy Hesitation
    I have just started to notice a slight hesitation/cough when coming on boost in the higher gears. If I'm sitting at about 2k RPM in 4th or 5th and floor the throttle there is a little cough/slight hesitation just as its coming on boost. Its the only time I notice it and its now getting on my nerves - what could be the issue?
    Cheers guys
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,078
    Boost leak perhaps?
    May 2010
    West Sussex
    157
    Could be a coil pack breaking down that is under load more in higher gears, spark plug, turbo, boost leak, D/V............
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Sounds like misfire or boost leak.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Could a few things, get a vagcom/vcds scan
    my hesitation issue was temporally sorted by the cleaning of the MAF
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    I had similar problem with mine last week in second, to forth gear, but was removed when i cleaned the MAF, which was surprisingly dirty.
    Still ok at moment.
    It's better to burn up, than to fade away...
