Monster MotorsportChris Nott
Results 1 to 14 of 14
    Jun 2010
    Air Con Drip Normal?
    Hi folks Im a newbie here so please forgive a dumb question maybe. I have recently bought an R reg A3 with a 1.8 engine. This morning I have small puddle of water on my drive, its definately water and doesnt taste of antifreeze.
    It appears to be coming from the right front lower spoiler area below the rad. and lower rad hose. The rad and hoses appear dry with no leaks. Im therefore wondering if this is some sort of drain for the air con? Is it normal?
    Thank you in advance
    Mark
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Markadrian View Post
    Mark
    Sounds like the rad tap leaking to me. Air con pump is over the other side of the engine, so I can't see it being that.
    Have you got headlight washers?
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    Mark are you talking right front from in the car or looking from the front
    im guessing the leak is below the battery area?
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Jun 2010
    Thanks for the replies its the right side of the car as I stand infront of it ie an offside leak. Theres no headlight washers on my model.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Have a look at the rad tap first then.... That's where it live, on the bottom at the back of the rad.
    Homer Simpson
    Jun 2010
    Thanx Welly I will recheck. I ran my hand all round there this morning and all felt dry. If it was from the rad tap wouldnt the water taste foul from the anitfreeze as it does in the top up bottle? There is a pipe coming over from the air con pump thingy down to the general area of the leak. Let you guys know how I get on, thanx so far.
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    I should hope it doesnt taste of antifreeze, http://news.bbc.co.uk/1/hi/england/w...re/4701360.stm, im sure this is more than you may have ingested
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Cookstein View Post
    I would guess so, he put quite a bit in that bottle according to that article. if there was only a inch of coke, and 2 inches of anti-freeze on top, then that must be 150 ml.
    Talk about a prank gone wrong....
    Homer Simpson
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    yep, bet he feels pretty bad
    Alex S3 AMK
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    He will do when he's getting buggered by bigger boys for 7 and a half months (which is what he will likely serve).
    Don't drop the soap pal.... Bon Voyage.
    Homer Simpson
    Jun 2010
    LOL, nah it was only a finger taste. Well ive had a look and the rad tap is dry, the water has evaporated from the drive without staining. No antifreeze lost when looking at the expansion/fill bottle. Back to the drawing board I guess.
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    lol, no i didn't expect that you'd got to your hands and knees to lick the tarmac dry
    Alex S3 AMK
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,078
    I was about to mention the "doesn't taste like antifreeze" comment, but will now refrain.
    Jun 2003
    World of my own
    9,813
    If it's straight water then it will be the climate control, run the car for 10 minutes on a hot day or so with the A/C on and it will piss water out. The A/C system takes all the moisture out of the air and it has to go somewhere, totally normal, nothig to worry about. There's no other area of an engine that will leak pure water.
    Alex Turner
