Monster MotorsportEM Tuning
Results 1 to 9 of 9
Thread: De-cat
    Turboman-a3's Avatar
    speed thrills
    Apr 2010
    portsmouth
    153
    De-cat
    Hi guys just wondering where I can get a de-cat for my 1996 a3 1.8t ? Is it worth knocking out the centre I just couldn't believe the restrictiveness of the downpipe behind the turbo
    I'm having a custom exhaust built soon and they said it would be cheaper to buy a decat then for them to make one? Any help apreiciated guys
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I'd buy a downpipe and a decat personally, and not get a downpipe made.
    You can get both of them on Ebay here: http://cgi.ebay.co.uk/VW-Golf-GTi-Be...#ht_2406wt_911 for 85 plus postage.
    If they can make you a downpipe for less than than, then I'd be 100% astounded.
    Homer Simpson
    speed thrills
    Apr 2010
    portsmouth
    153
    Sweet looks just what I want it says fits 1998 onwards but it should fit a 1996 surely? If not I'm sur they can adapt it for me cheers welly
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yeah, if It's got a K03 turbo it will be fine.
    Homer Simpson
    Mar 2010
    Porthcawl,Wales,UK
    63
    what if it has a ko3s turbo?
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Same housing, just K04 internals IIRC, so would take the same downpipe.
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Bit off topic but I've often wondered if removing the centre box would give a slightly more aggressive exhaust note ?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Bigphil92 View Post
    Quote Originally Posted by JD09 View Post
    K03S is exactly the same shape chassis as the K03 (with the exception of the cold side outlet), however has a more efficient and better design compressor wheel than the K03.
    The K03 compressor wheel has12 blades, the K03S only has 8, and they have a deeper pitch. Basically, it is a revised model of the K03-011 (which was fitted to most K03 VAG engine). The K03-052, 053 and 058 are the revised (K03S) models.
    Not quite a K03 with K04 internals, although they can be bought as a hybrid.
    Picture of the two compared:
    In answer to your question, yes, itt will fit. Any downpipe that fits a K03 WILL fit a K03S.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by wibble111 View Post
    Yes it will, removing any silencing from the exhaust system will increase the level of volume at the tailpipe.
    Homer Simpson
