EM TuningChris Nott
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 95
  1. #41
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    19mm hex for sump plug, 5mm hex for turbo oil drain
    5mm hex drive, ball end for those by the bell housing.
    vag sump sealer tube
    10mm hex socket to drop off the pump pickup
    gunk, rags
    threads on these bolts are m7 so dont loose one, you will not find one like it in your bitty box
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  3. #42
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Cheers for that Badger, I will get those!
  4. #43
    Dazboss's Avatar
    Like A Thristy Dingo ;)
    Jul 2010
    366
    Im going to change my oil, Mobil 1 Super S 10w/40 this should be fine shouldn't it. Last owner used 10w/40 german brand (cant remember the make).
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
  5. #44
    Sep 2009
    Essex
    2,366
    prolly fuchs.
    i stick with 5w40 fully
  6. #45
    Sep 2009
    Essex
    2,366
    i found this out a couple months ago changing the clutch/flywheel on an a3. m7 bolts. lose one and theyre like rocking horse poo!
    torque wrench would be good for the list too
    10nm on the sump bolts
  7. #46
    Dazboss's Avatar
    Jul 2010
    366
    Quote Originally Posted by Matt82 View Post
    prolly fuchs.
    Thats the one he used !
  8. #47
    Sep 2009
    Essex
    2,366
    personally id stick with 5w40 given how hot these things run and how they like to bake oil
    fuchs do a lovely one, i stick to quantum platinum as value wise its hard to beat
  9. #48
    S3 Owner
    Feb 2009
    Aberdeen
    414
    J B - Can you take some pics and do a small writeup??
  10. #49
    May 2010
    West Sussex
    157
    Another job for me to do when changing the oil sensor on the bottom of the sump, seems stupid not to do it while the oil is dropped...
    Ebony black 99 S3, Forge 007, cone filter, goodridge braided lines, apex lowering springs. More to come...
  11. #50
    altank's Avatar
    Jun 2010
    23
    Now that most garages use a Vacuum Pump to extract the oil when doing a oil change, surly this can't be as good as removing the sump plug and doing a a proper drain ?
    I would of thought that all kinds of "stuff" is left in that sump ?
    05 Audi A4 2.0T FSI S-Line (B7) 132k Miles - SOLD
  12. #51
    Sep 2009
    Essex
    2,366
    absolutely. cutting corners normally has its pitfalls (same as only changing the oil every 20k!!)
  13. #52
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    Is a 5-30W fully ok for the S3 or should I be going for the 5-40W fully?
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
  14. #53
    Sep 2009
    Essex
    2,366
    either, but my preference is 5w40
  15. #54
    Dazboss's Avatar
    Jul 2010
    366
    Just changed my oil 2night first thing i do when taking ownership of a 2nd hand car. Plugs tomorrow & fuel filter on Monday.
    One thing i really want done is the Quattro oil & filter. Know anyone willing to help out ?
  16. #55
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    matt, another job for you....
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
  17. #56
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    when removing the sump is it just the 20 allen key bolts, the turbo return and the level/temp sensor that need removed?
    ELSA talks about 3 bigger bolts from the gearbox to the sump that need removed but i can't find part numbers for them, can anyone shed any light on it?
  18. #57
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    Quote Originally Posted by danger S3 View Post
    when i did the sump on my a3 it was just the allen keys, but on my s3 it had the 3 larger bolts as well
  19. #58
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    ah ok thanks,
    any idea what a part number for the 3 bolts is as it recommends replacing them? or did you just reuse the old bolts?
  20. #59
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    i just re-used them, didnt even know they were there till i got under it, havent had any problems so far
  21. #60
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by dela View Post
    Re-use them, you'll be fine.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
  22. #61
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    does the AMK S3 have the 2 bolts that you access through the flywheel cut out aswell?
    I have a diagram from elsawin and it just shows 20 bolts round the edge of the sump and the 3 big bolts through the gearbox but doesnt mention anything about the flywheel
    may be a stupid question, sorry if it is
  23. #62
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    also a mate is moaning at me telling me I would be stupid to not change the big end bearings while I have the sump off, I think that's slightly over the top and a considerably bigger job
    anyone else done this?
  24. #63
    DionBullock's Avatar
    Dion
    North Wales
    68
    Hi guys! i had this problem last week so i got a mate of mine whos done loads of vag cars up in his work. within a few hours and numerous cups of coffee later, he had taken the sump off, cleaned it and the pick up pipe!
    You would not believe the ****e that had formed from the old oil, ud swear it was granite!!! Audi's long life service plan can go to F**k from now on! lol he checked oil pressure before and after and was a-ok so oil pump is fine and everything else!
    Would have got some pics but i forgot my camera! My advice, change the oil every 6-7k miles???? dependant on ur driving style??? NOT the 20k Miles audi recommend! lol
    Its a cheap enough job to do (abit messy!) but well worth it for the peace of mind! :D
  25. #64
    ptr
    ptr's Avatar
    Aug 2010
    129
    Quote Originally Posted by 5ean View Post
    Seconded, I'm considering doing this
  26. #65
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    I'm planning to do mine this Sunday and I plan to take some photos and do a wee write up, I'll try and get it all up asap
    I've had all the bits sitting for about 2 weeks now but haven't had time to do it yet as stupid work keeps getting in the way, hhhhmmmm is 30 to early to retire
    Jimmp might be coming round to join in the fun as well and compare cars and stories
  27. #66
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,176
    Great, some pics would be great to see. Mine probably needs doing at some point. Oh yipee.
  28. #67
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by The Doctor View Post
    It's easy enough dude - just fiddly and dirty. Well worth the hassle it causes you to do it....
    Homer Simpson
  29. #68
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    yeah totally, dropping the sump and cleaning it and the pickup is a hell of a lot easier and cheaper than getting a new engine
  30. #69
    ptr
    ptr's Avatar
    Aug 2010
    129
    Thanks, would be good to see some pics of what to do.
    I'm 22 and work keeps getting in the way of working on the car, I've got no chance!
  31. #70
    Sep 2009
    Essex
    2,366
    done a few more of these lately, AUMs always seem to be the worst
    best one though had an oil pressure gauge. just over 2 bar oil pressure when hot, at idle. after 2.8! big big difference
  32. #71
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    I take it the oil pressure should be about the 3 bar level?
  33. #72
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    Anyone got part numbers for the oil pickup filter and pipe if the parts are only 12?
    TT pedals
    N249 bypass
  34. #73
    barters3's Avatar
    May 2008
    440
    Just read this, will get mine seen to on the next service. Its done 105k, not on longlife intervals but i would mind betting its pretty snotted up. I dont think il do it myself though.
  35. #74
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Has any one got the part numbers for the oil pick and is it strainer, not sure if their the correct terms, if their not correct me, but the two parts that are recommened to be changed.
  36. #75
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    they are the correct terms. if your thinking of replacing it because its dirty you dont have to, i cleaned mine up with brake cleaner and petrol, and it came up brilliantly!
  37. #76
    Aug 2010
    1,540
    i cant struss enuf..... do do this if your cars been on the long life service plan. ive just changed the engine on a 2002 ary 180 engined tt at work.
    the exhaust cam had partially seized in the head. spun the cam pulley on the cam by breaking the woodruff keyway. bending valves. bid end bearings were worn.
    yep you guessed it, 120k long life servicing..... oil pump pick up was blocked full of bits of hard carbon.
    an engine any engine cant have enuf oil changes!
  38. #77
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    428
    I did this to my s3 the other day.. its done 80k and has been on long life servicing its entire life. After a bit of a thrashing the car would sound noisy, all is good now. Deffo recommend to anyone that hasn't done it.
    I'll post some pics up when i get a chance, the pick up was more or less totally blocked and it took me over an hour to clean the sump with a drill and a wire brush attachment bit.
  39. #78
    May 2010
    139
    Will be doing mine this weekend depending on weather and work =/
    Got a box load of bits to change on the car and just got to get some bits to actually clean the sump and pickup pipe up with.
  40. #79
    Aug 2010
    1,540
    tbh this is a prime example of how cars have gone backwards......... in the olden days of vag cars (im talking late air cooled stuff and mk1 golfs here) there used to be a low AND a high oil pressure switch. the low pressure switch (in the block) used to be like .6.8 bar looking for that pressure at tick over to 2249 rpm. the high oil pressure switch (in the head) used to look for like 2 bar above 2250 rpm. (revs and oil light switches sensed at the dash pod)
    these modern vag cars only have the low pressure switch which means you could be bombing down the motorway at 90mph, stereo booming..... with your blocked oil pump pick up..... having .9 bar of oil pressure (insted of 4-5 bar) completely unaware your engine is eating itself!
    scary really!
  41. #80
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    Agreed this is DEFINATLY something that should be checked on all cars.
    i would do a flush before dropping the sump and cleaning the pickup. when i did mine i didnt do a flush and im wishing i had. i am planning on doing a flush and dropping the sump again to make sure none of the wee bits of crap have made there way round and blocked it again because there was quite alot of them.
    Check the camcover breather hoses aswell as they were also blocked on mine with thick burnt oil
    I also removed and cleaned the cam cover as there was lots of burnt on oil there too
    there is a wee guide in the stickies that might help S3 Sump Removal and Refit
