Chris NottEM Tuning
    Oct 2009
    150
    fault code help please
    hi, a friend of mine the n*b happened to buy an s3 exactly the same as mine. i plugged my fault finder into it and came up with 4 codes. 2 are straight forward however, 18010 and 17963 could be multiple solutions. has anybody else had experience with the 2 codes and what did they find solved the issue? any advice would be much appreciated.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Chugger
    North Devon
    2,716
    18010 is a fault that seems to come up if the battery was ever run flat, i think this stays until its cleared.
    other fault is this:
    17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
    Possible Symptoms
    • Reduced power output
    • Limp mode
    Possible Causes
    • Boost Pressure too High
    • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    • Charger Pressure Control defective
      • VNT (variable nozzle turbo): nozzles stuck
    • Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    • Check Hoses/Pipes to/between Components
    • Check Solenoid Valve for Boost Pressure Control (N75)
    • Check / Clean / Replace Charge Pressure Control
      • Check / Clean mechanism for variable nozzles
    57 A3 2.0 TDI Sportback (140)
    Chugger
    North Devon
    2,716
    touche, tuffty beat me to it
