Monster MotorsportChris Nott
    May 2010
    151
    Couple of things :S.
    Hi there guys,
    I have a mapped s3 that has done 112k , I have been noticing a few things recently which ideally i need sorted.
    One is a rather lumpy idle, it doesn't move the needle much just the note of the engine just bummbles and bumps away is this normal ?.
    Also once the car is warm say you park up then come back to it when you restart it sometimes trys to cut out as the revs drop to low or does actually cut out :S.
    Could these be related ?.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    couple of things you could do: clean your maf, throttle body clean reset, do a vagcom scan an d find out if ur crank/speed sensor is failing, check for split in pipes
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    ps clean maf with electrical contact cleaner .
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by cawsey20 View Post
    Hi there guys,
    That sounds like a vac leak to me mate, those are very common symptoms of a split pipe allowing unmetered air into the engine on idle.
    Go around all the hoses with a fine tooth comb - check especially the N75 area, and underneath the inlet manifold.
    Homer Simpson
    May 2010
    West Sussex
    157
    Lumpy idle could also be spark plugs.
