    20
    ESP/traction control light
    Hi all,
    I've just started up the s3 and the asp light came on. I tried to turn it off and restart the car, but no joy. Does anyone know what causes this and how to solve it?
    Graham
    fran-s3's Avatar
    1,090
    Yes I think you mean the ESP light? Yes it means you're car has developed a fault and needs to be plugged into a diagnostics machine for the faults to be read. I suggest you try and find a local member here with VAG-COM or be prepared to pay 50 at Audi for them to do it... Either way it needs to be done I'm afraid, car running ok? Down on power?
    20
    Sorry, I meant ESP light! I unplugged my maf and took it for a spin as I wanted to check whether that was the cause of the slight boost delay I get. It came on when I unplugged it and stayed on after I turned the engine on and off again, however, It wasn't showing this morning and it's not down on power at all.
    Anyone near Didcot that could help out with vagcom?
    Many thanks
    Graham
