Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Bignick's Avatar
    Jul 2008
    Kent
    165
    How can i beat this quote its insane?
    I'm getting really bord of my 1.8T now and i wanted to go for a KO4 with a decent map, After looking at this i might as well by an S3 which i dont think the misses will go for. Any suggestions would be good?
    Hello Nick,
    Thank you for your enquiry ref your A3.
    I would recommend going for a KO3s hybrid over the KO4 as the KO4 requires a lot more parts and is not direct bolt on like a KO3s hybrid. Gains would be around the same too.
    Price wise you would be looking at
    Hybrid turbo - 1095 + vat
    Removing old turbo and refitting new - 240 + vat
    Turbo fitting kit, oil feed pipe, gaskets seals, oil etc -110 + vat
    Turbo Intake pipe - 121 + vat
    4 Bar pressure regulator - 50.21
    S3 Injectors new these are around 300 each! I would suggest sourcing some second hand ones
    AmD Re-map to suit modifications - 424.68 + vat
    To maximise power and be able to up the boost it is also recommended to fit a boost controller this is 250 + 120 for fitting.
    Hope that helps but if you do have any further questions please do not hesitate in contacting me.
    The light that burns twice as bright , burns half as long.
    Jun 2009
    1,064
    send your turbo off to cr turbos or someone alike, that costs about 600 for them to hybrid it, so thats 500 knocked off, youd save loads doing it yourself too, you need a fmic !
    Its gone replaced with a mk2 golf gti 16v :D
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,845
    For the price of the upgrade, I think buying an S3 is better value in my opinion, depends how much you want 4WD(if you can call it that), and higher running costs in general.
    You've got to have a laugh!
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,065
    that's an INSANE price quote.
    here's what you should do:
    CR turbos ko3/4 hybrid: 600
    Turborevs ebay FMIC: 200
    S3 injectors: 100
    S3 MAF housing 50ish
    Ebay 3''DP/decat 100
    Autobahn88 TIP 80
    Rtech custom map 400
    Much much much cheaper. AMD also forgot to mention you need the downpipe, S3 maf, and a FMIC.
    Muppets
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    717
    Have aways wondered about the financial logic of modifying an A3 over the cost of buying an S3, I understand the enjoyment of modding, but do think the S3 represents much better bang per buck than modding an A3
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,065
    Without wishing to start another one of 'these' threads, the arguement is, that for a given price, you can have either a modified A3, or a standard S3.
    The modified A3 for std S3 money will be much faster than the S3, and handle better, and be much more exciting to drive.
    That argument of course goes out of the window when you start doing similar mods to the S3, but to buy and properly modify an S3 will cost you in the region of 10k, compared to about 5k to buy and mod an A3.....
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Bignick's Avatar
    Jul 2008
    Kent
    165
    Thanks for all your input guys, it dose have a FMIC already and a 3" DP. So when i make my mind up what to do i'll let you know and post the results. Its currently putting out 201 bhp but that was done over 2 years ago so should be quite interesting.
