JMB RetrofitsBadger5
Results 1 to 9 of 9
    Mar 2010
    South Africa
    72
    Do I have to let the car idle before switchn it off?
    Have a pre-facelift 1.8T just want to know if I have to let te car idle after a trip before switching the engine off?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    depends how you have been driving
    Chugger
    North Devon
    2,716
    I dont bother on the s3 as it has the water pump to continue cooling, but if you havent got that it probably is a good idea, that or take it easy for end of trip.
    57 A3 2.0 TDI Sportback (140)
    Sep 2009
    Essex
    2,366
    the water pump wont make the blindest bit of difference. have you seen how hot a turbo gets?
    the simplest advice i have is just use the absolute minimal boost possible for the last part of your journey (the longer/harder the drive, the longer you keep it off boost for)
    the idea is you get as much heat out of the turbo as possible before switch off so that you dont have oil circulation stop inside a baking hot turbo as the heat cooks the oil in place
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    664
    get a turbo timer :P
    Sep 2009
    Essex
    2,366
    do you get those if you save up all the tokens on the back of your packets of rice?
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    664
    hehe, no hard feelings mate
    while i was reading on some thread on asn, they concluded that cooling down the turbo isnt really necessary in normal/medium driving conditions.
    turbo must be left to cool down in a mapped car that has been driven hard enough to make the turbo really hot, if thats your case then i suggest let the car idle for 30 seconds - 1min depending how hard was the ride.
    Chugger
    North Devon
    2,716
    Quote Originally Posted by Matt82 View Post
    yup iv had mine glowing orange before, but to get it like this you have to be driving like a loop, in which case i wouldnt just stop the engine. Of course the water pump does something else it wouldnt be there, it must help.
