Sky InsuranceAH Fabrications
Results 1 to 10 of 10
    imported_andrewriding
    Revs fluctuating
    My A3 (T Sport) has started fluctuating on the rev counter. In a morning I start the engine and the revs hit about 1200rpm without touching the accelerator (I put this down to being cold so no worries). But...
    Once the engine has been on for 10 mins or so the revs drop back to about 750rpm (this is where it is normally) but if you sit and watch the rev counter the revs will fluctuate (usual range is between 600 and 1000rpm) anywhere between 1400rpm and 500rpm (it really starts to struggle at 500rpm). This has been happening more often and will generally calm down by the time I finish my 45 minute drive to work - but will be noticable at every set of traffic lights along the way.
    While it isn't a massive problem at the moment it is really annoying. Before i wheel it into the local dealer and part with all my cash, can anyone give me an idea of what could be going on with it. And more importantly does it sound expensive... [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Thanks in advance
    mark69's Avatar
    Nov 2004
    Frimley, Surrey.
    58
    Re: Revs fluctuating
    I have had very similar symptoms in the past that were traced (eventually!) to the throttle body. This was thoroughly cleaned at the stealers (twice) which temporarily rectified the problem only for it to gradually return although nowhere near as bad. Currently I am 'living with it' as AUDI are asking 280+
    for a replacement......hope you get it sorted soon as I know what a pain in the arse it can be. Good luck , Mark C. [img]/ubbthreads/images/graemlins/wink.gif[/img]
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,707
    I have this happening only on first start-up on cold mornings, they are like this OP has, I too have cleaned the throttle body but still have this problem, it seems to want to cut out and has on a few occasions has anyone else had this and found a cure as nothing has come up on Vagcom. Its on an S3 2001 AMK
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Talk about a necrobump!
    I'd suggest it could be a vacuum leak.
    TD5 Land Rover Defender build
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,707
    Yeah I googled fluctuating revs and got this lol I will have a look at my lines as I did the N249 bypass before christmas so il check for any splits
    Thanks, Chris
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    this turned out to be a dirty tb for me. my symptoms were bouncy idle after dipping the clutch. very annoying and sometimes cut out.
    A3 1.8T Sport (98)
    Fusion Stage 1 Remap
    Pipercross Panel Filter
    Forge 007p Recirc Valve
    Stainless Exhaust
    G60 Solid Flywheel & VR6 Clutch
    3 Careful Owners
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,707
    Quote Originally Posted by A3 Oly View Post
    Sounds exactly the same I sprayed some throttle body cleaner in mine but didnt make much difference I feel your pain as it drives me nuts sometimes.
    Cheers, Chris.
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    take the tb off mate and give it a god clean with carb cleaner . ether get a new gasket or make sure you dont break the one on there. once done tho u will need vagcom to realign the tb. car feel much better once it has adapted.
    A3 1.8T Sport (98)
    Stainless Exhaust
    3 Careful Owners
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,707
    That will be beyond my talents lol and I dont have vagcom either so will be stuffed, guess il get a garage to do it chuffin cars should call them bottomless pits lol.
    Cheers, Chris.
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    tb is easy to take off and clean. where are u in midlands?
    A3 1.8T Sport (98)
    Stainless Exhaust
    3 Careful Owners
