Monster MotorsportChris Nott
Results 1 to 9 of 9
    S3 Paul's Avatar
    Oct 2006
    2,764
    Vag Com Logging which measuring blocks tell me if the car is doing what it should??
    I did a few searchs ( before i get told off )
    But i didnt realy find a straight forward answer...
    My car is a 2001 S3 with a few mods and a phase 3 map,
    I have vag com ... i think its only the 311.2 version or something and just wondered which groups of 3 measuring blocks i should log together to show wether the car is running spot on and if it has been mapped correctly.
    Also... once i have logged these blocks how do i go about posting the logs so people alot cleverer than me can take a look??
    Many thanks
    Noggy Blue 2001 S3
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    From 3rd gear, 2000rpm to redline
    1. 002 031 115
    2. 002 115 119
    3. Take note of the two values of block 032 when idling after the run
    002 : Airflow
    031 : Lambda actual value vs Lambda specified value
    115 : Boost pressure specified value vs Boost pressure actual value
    119 :
    Duty cycle boost pressure control valve vs Boost pressure before throttle valve
    ps is your S3 really pink?
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    S3 Paul's Avatar
    Oct 2006
    2,764
    Thankyou,
    Although i wish it was... its not..
    and its not realy got as much power as my sig says...
    Its much less
    Noggy Blue 2001 S3
    S3 Paul's Avatar
    Oct 2006
    2,764
    So which blocks would you log to show if an intercooler upgrade was working well?
    Intake temps v ??
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Block 118 will give you AIT's, will also show actual boost too so you can see how AIT's are affected under boost... logging block 020 is useful while doing AIT's as you can see if any timing pull you get maybe related to higher AIT's... Block 112 gives you EGT's....
    <tuffty/>
    S3 Paul's Avatar
    Oct 2006
    2,764
    Thankyou paul.
    Hoping this will help others too
    Noggy Blue 2001 S3
    Chugger
    North Devon
    2,716
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    tuffty what would you consider a unhealthy timing pull. After logging mine I was getting a 6-7 on cyl 4, and 4-5 on cylinder 3 between 4100 - 5200 rpm? Cyl 1 and 2 remain on zero
    57 A3 2.0 TDI Sportback (140)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    3's ideally, 6's at a push (as long as its not all the time) but if you get more I would look into why you are getting them...
    Timing pull is going to be more in the hotter weather unless you have a good FMIC... recent S3 in the workshop had an APR stage 2 but didn't have a FMIC fitted... was pulling 9's IIRC... ouch!
    <tuffty/>
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    That's good to know. I was pulling 5.3 at 20 degrees AIT on one cylinder! That was back in Feb. I think its time for that FMIC
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
