Chris NottAH Fabrications
Results 1 to 23 of 23
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Question AH intercooler fiiting with fogs?
    Fitted this piece of kit over the weekend with help from the guide on here so thanks very much for that! Just a quick question, when i put the bumper back on there was no way i could refit it without removing the fog lights! I removed them both and the brackets still foul a little on the pipes. Is there anyway of keeping the fogs?
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    yes, invest in an angle grinder for the inside of the bumper and trim your pipes more
    there is no easy way to do it, as long as your running 51mm pipework then it is possible as has been prvoen by a few owners now
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    www.badger5.co.uk
    May 2004
    nr Glos
    6,941
    tufftys running fogs in his AH fmic
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Where is it fouling? I used washers to space the FMIC down a bit to get it in the right position... this was by design... you may fine that you will have to do the same as fitting the brackets directly to the crash bar will sit the FMIC too high..
    <tuffty/>
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    It is fouling on the brackets for the fogs, it either needs to be raised or lowered (intercooler). I mounted the intercooler brackets underneath the crash bar too. Then again you dont legally require fogs, the look of the car doesnt look too bad with them out!
    Ok i plan to take another look at it the end of the week and see what can be done, cheers for advice guys
    >Campbell
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    I packed down from the bottom of the crash bar...
    When I went to see Alex for final fitting, neither of us knew where the brackets would sit so after a bit of playing about with the height of the cooler so it was sitting about right he marked up where the brackets would go. I then suggested that they were fitted a little lower to allow for some fine adjustment with washers...
    In this picture there are about 3 washers to lower the cooler from the crash bar, you may need more or less than that but it was part of the spec I gave Alex when I asked him to make a FMIC for an S3.
    <tuffty/>
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Thanks Tufty, thats about the same height i have mine. I didnt cut down any silicon or aluminium pipes though so i guess thats the next step, will have the bumper off sometime this week
    Thankyou
    Oct 2008
    218
    I trimmed the back of the bracket on my bumper,and mine fitted fine... Only prob i have is, ive lost the flush gap under my headlights,but ohhh well...
    Good bit of kit though...
    Pete...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Quote Originally Posted by warleydaddy View Post
    ...Only prob i have is, ive lost the flush gap under my headlights...
    You sure you fitted the bumper back on ok? there are a couple of 'tangs' on the bumper that slot in to a 'special' slot under the headlights, its easy to fit this under that slot and you get the gap that way...
    <tuffty/>
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Yea im pretty sure its in that special slot, i will have to double check. It seams that even if i trim my pipework it still wont fit with the fogs in place!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Unless something has changed with the cooler I can't see how you wouldn't be able to... it was designed with that very thing in mind...
    Get some pics up, might be able to see what the problem is
    <tuffty/>
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    sill question but how do upload pics?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Upload to somewhere like Photobucket and add them to a post using the 'Insert Image' button () or I think you can upload to an album on ASN from the settings menu.
    <tuffty/>
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Cheers for that Tufty, another question, audi-sport is not loading up as it should be-the page is all muddled up. How do i correct this?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Quote Originally Posted by campbell View Post
    Ctrl-F5
    <tuffty/>
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Tufty have you got a photo of the piping arrangement behing you fog lamp cover, bumper insert (they can be pulled from the front to remove)?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Tufty have you got a photo of the piping arrangement behing you fog lamp cover, bumper insert...
    Loads of pics here...
    http://s84.photobucket.com/albums/k3...r/S3/FMIC/asn/
    (they can be pulled from the front to remove)...
    ...thanks for the tip
    <tuffty/>
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Tufty you are the man, ill get the intercooler sorted properly this weekend. Its made a difference to the performance, more responsive and no more lag ! No worries about the tip ha ha
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Whats the dimensions of this cooler and what core does it have?
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    654
    i am interrested in the dimensions too!
    and related to lemonS3 thread concerning what can be bought in the USA, here is a couple of ebay intercoolers kit that i think might fit the S3, for sure some modifications are required but for the price....i can modify it a lot lol
    http://cgi.ebay.com/ebaymotors/ws/eB...fvi%3D1&_rdc=1
    http://cgi.ebay.com/ebaymotors/AUDI-...item5ad8f5f9e7
    http://cgi.ebay.com/ebaymotors/AUDI-...item2c542f5ea9
    http://cgi.ebay.com/ebaymotors/AUDI-...item2c53e06543
    sorry guys too many links
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    654
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    All this information has been covered...
    dimensions and ones I used as the spec for the FMIC AH built me...
    http://www.audi-sport.net/vb/showthr...GE-INTERCOOLER
    FMIC fitments on the S3, AH, Forge and varying ebay coolers...
    http://www.audi-sport.net/vb/showthr...C-(image-heavy)
    Searching on FMIC will bring back lots of info that you will need to sift through but the info is out there.... you can get other FMIC's other than the AH and Forge to fit the S3 but you will need to do some work and potentially compromise on things to get it in...
    Its not just about the core size here, the end tanks and outlets play a part in how easy your life is going to be...
    AH and Forge FMIC's are no fuss solutions... ebay coolers will require effort...
    <tuffty/>
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    654
    I will order one of those anyways...I have readed those threads many times lol.
    I will give it a try but since many are available i am trying to get a kit that is the most similar to what you guys have used....forge or AH.
    I wont receive it until 20 days or so and when i will have time i will install it with pictures and as much details as possible so it will answer more questions concerning the cheap FMIC mod DIY...the cost is 200$ (around 130 pounds) includinf the interooler, pipes and brackets
