JMB RetrofitsSky Insurance
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    S3 Central Locking stopped working
    Hi folks, have tried the seach facility but no joy. Parked car last night and locked it on the remote as normal. Went to use it today, it wouldn't unlock from the remote, tried other remote which is brand new and same problem. Car unlocks with key fine. I can hear the pump working, but no lock/unlock. Any suggestions guys? I have run VAG-COM and no codes showing, all fuses checked and OK.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Sep 2009
    741
    If it helps amyone with a suggestion, the indicators flash on the remote lock/unlock but nothing actually unlocks or locks, if I use the key I can unlock the car and it starts OK so the immobiliser must therefore be disarmed, all fuses are OK will be taking it to Audi on Monday if now suggestions as it's a real pain having to remember to lock it with a key.
    Thanks in advance
    Nige
    vetch's Avatar
    S3
    Apr 2009
    412
    Have you checked the central locking pump? It may well be working but one of the air lines might have snapped or come loose etc? Its tucked away down by the sub in the boot.
    Audi S3
    Sep 2009
    741
    Just back from Plymouth Audi who have diagnosed the problem as being the pump, new one being fitted tomorrow quoted 535.76 fitted but not overly bothered as I have aftermarket warrantee that will cover it less the 50 excess - will post update once fixed hopefully.
    Boggle's Avatar
    May 2010
    London
    88
    you can buy a recon kit for 38 pounds off ebay all it is are the graff parts in side have broken down i bet
    Sep 2009
    741
    Quote Originally Posted by Boggle View Post
    To be honest for the sake of the 50 excess on the warrantee is rather have a new pump than pratt about trying to rebuild the old pump with an ebay repair kit. But thanks for the tip anyways.
