http://www.thetradepartsspecialists.co.uk/flash/quantum/product/102131%20Quantum%20Platinum%20Product%20Data%20Sheet.pdf
1. Description/Application
Quantum Platinum is a fully synthetic SAE 5W-40 engine oil for all year round use in applications where an oil of that
viscosity grade and performance level (API SL/CF, ACEA A3/B4/C3) is recommended, in particular high performance
vehicles and those under arduous conditions, such as extended high speed driving, towing and high temperatures.
Quantum Platinum uses an optimised blend of full synthetic base oils and a carefully selected and balanced additive
system. Quantum Platinum is suitable for use in Volkswagen Group Pumpe Düse engines (meets the VW 505 01
specification) on fixed service intervals. Not suitable for VW Group vehicles following a Variable Service regime.
2. Features/Benefits
• Full synthetic formulation ensures optimum high temperature performance and oxidation resistance
• Excellent thermal stability and superior wear protection to meet the specific demands of the Pumpe Düse
engine design
• Low ash formulation to maintain Diesel Particulate Filter (DPF) performance (note: VW Group vehicles fitted
with a DPF must use Quantum LongLife III oil)
• Specifically formulated to provide improved fuel efficiency when compared to conventional engine oils
• Excellent low temperature flow properties ensure rapid oil circulation for efficient cold starting and initial
wear protection
• Low volatility reduces oil consumption and can improve catalyst life
3. Performance
SAE 5W-40
API SL/CF
ACEA A3/B4/C3
VW 502 00 / 505 00 / 505 01
Ford WSS M2C-917A
4. Technical Characteristics
SAE Viscosity Rating 5W-40
Relative Density at 15°C 0.85
Viscosity at 40°C, mm2/s 75
Viscosity at 100°C, mm2/s 13
Viscosity Index 173
Pour Point, °C -42
Flash Point, (closed) °C 203
5. Availability
Description: Part Number:
1 litre ZGB 115 QLB 005 10
5 litre ZGB 115 QLB 005 11
20 litre ZGB 115 QLB 005 12
208 litre ZGB 115 QLB 005 13
Bulk 500 litres+ ZGB 115 QLB 005 14
Bulk 1000 litres+ ZGB 115 QLB 005 15
