Chris NottBadger5
    Nov 2004
    6
    Changing springs on S3
    Can someone run me through the process of changing the springs on a 1999 S3. Is there any special tools required and has anyone come across any problems.
    Thanks [img]/ubbthreads/images/graemlins/froggie_red.gif[/img]
    Stepho's Avatar
    Feb 2004
    Strathclyde
    444
    Re: Changing springs on S3
    You will have to remove the front struts, and use spring clamps. The rears are a lot easier just need to remove the lower bolts on the dampers and the springs will lift out. A good couple of hours work and would advise you get some assistance.
    Nov 2004
    6
    Cheers for that, sounds a lot easier than my Integra !
