Badger5JMB Retrofits
Results 1 to 10 of 10
    Boggle's Avatar
    May 2010
    London
    88
    just tryed the lcd repair
    o well i was not lucky enuff to get here back in shape looks like i will have to pay the 149 plus the VAT or i mite just give it one more go as i need to get the clocks out to reset the dam rev and speedo niddles :-(
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I'm sorry mate, but I have no idea what the above is supposed to say....
    Did it work or what?
    Homer Simpson
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Lol.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Yeah should of told you mate it makes it worse lol, fooked mine up big time.
    What you mean by your going to pay 149? Whats that for exactly?
    c_dog's Avatar
    Apr 2008
    Sussex
    99
    2001 A3 1.8T TQS
    1998 A8 2.8 Auto
    Dec 2010
    Hello, just had two goes trying to fix the LCD on my Audi A6. First try made it worse, second maybe made a bit better. The main issue I had was trying put the dials back on correctly, I had to fit them while the dash was connected to the car -it was a real pain. It looks like you can buy new LCD's for 40 on ebay. Fitting them though looks like a tricky job. I'm not sure if it's the solder joint or the connection to the LCD that's is the problem.
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    299
    hi mateys,
    give me a bit of info on where you're getting stuck: i've taken apart my dashpod and put it back together a few times in my efforts to fix the LCD..
    Audi A3 8L 1.8T Quattro 180 in black. Totally standard: for now...
    Dec 2010
    Hello, I used one of the 'How to' fixes on the 'UK Audi' forum site. It advised you can re-attach the cable by heating it up and re-sticking the glue -it's so far not been successful or I've not done it right. To completely replace the lcd looks a bit more tricky still.
    Have you managed a heating fix or a full re-solder and new lcd?
    How much do you heat up the cable and which bit has the bad connections the LCD or soldered end?
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    299
    hi lads, the problem often isnt the cable attachment: apparently the cable can develop hairline cracks in it... no amount of glue is going to fix things i'm afraid! its the top bit of the cable which is attached to the lcd itself btw.
    Dec 2010
    Thanks for think bit of info, that does make sense -but looks to be bad news as far as any cheap fix goes :-(. Will look on Ebay for a replacement.
    Have you done a re-solder job with a new LCD panel? I've seen some walkthroughs on the procedure, need the right tools for the job and some expertise, plus I could end up with no display and no dash if it goes wrong :-).
