Badger5JMB Retrofits
Results 1 to 29 of 29
Thread: My Logs!!!!
    luke2702's Avatar
    Chopper Challenge Champion
    Apr 2010
    Bolton
    446
    My Logs!!!!
    Just done quick logs with my mate what do you think?
    because the code button doesent work properly had to put them as am image hope you all can still see them properly.
    2002 S3 8L, FORGE 007, R-TECH RE-MAPP, MILTEK CAT BACK NON-RESONATED, JETEX CONE FILTER AND 260 BHP ISH.......
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Unreadable mate, sorry.... screen shot the relevant rows in excel (freeze the top panes with the log headers in) and post them up
    <tuffty/>
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Should be able 2 now..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Ok.... apart from pulling 6's (which is verging on too high) everything looks ok, biggest problem is that they are not comparitive... you did the logs separately rather than meaningful blocks together....
    As the aiflow looks ok (actually very good considering) I would do blocks 020 (timing pull), 031 (fuelling) and 115 (boost) together... if you are expecting to see a problem (such as your timing pulls of 6) then you need to see what boost was doing and what fuelling was doing at that time the timing was pulled so you can see what maybe causing the problem. Timing pull is the result of something happening (lean mixture, high cylinder temps etc) that the ECU doesn't like... without the other blocks side by side there is nothing to show as to what happened to pull it...
    <tuffty/>
    Chugger
    North Devon
    2,716
    the maf readings and pressure at intercooler looks pretty good to me. Its definately mapped, whats the problem with it
    57 A3 2.0 TDI Sportback (140)
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Not got any problems i didnt think! is 6's anything to worry about? Just wanted to do logs to try and find what bhp car was doing. Think it is about 260bhp but correct me if i am wrong.
    Chugger
    North Devon
    2,716
    about that according to your maf readings
    RIP S3dave
    May 2004
    nr Glos
    7,199
    logs look ok... turbo fails to achieve the mid range requested boost, so might be tired, or restricted in some way, although airflow is healthy
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    What do i need to look for if it is restricted?
    Chugger
    North Devon
    2,716
    well I decided to go out logging and see what I was getting with regards to timing and fueling as Iv never tried it before.
    as you can see its pulling well out on cyl 3 + 4 at close to the limiter. The log shows 3 or 4 runs in 3rd and 4th. previously only been able to hit 200g/s. Hope this gives you something to compare
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Will ask my mate to have a look he makes more sense off stuff!!!!
    May 2010
    We did some more logs on lukes car tonight after we have fitted the new jetex filter and done the n249 bypass.
    Its giving a very good air flow just worried about the cf's started to creep into 9's but luke has 95 petrol in so that could be half the problem.
    Anyway see what you lot think.
    Code:
      Group A:   '002
      Engine RPM   Engine Load   Ave. Inj. Period   Air Mass Flow
      TIME
          MARKER   STAMP    /min   %    ms    g/s
      0.02   1840   59.4   5.78   21.56
      0.5   1880   58.6   5.78   22.17
      0.9   1920   57.1   5.1   21.67
      1.31   1960   57.1   5.1   21.17
      1.71   2000   91.7   8.5   39.58
      2.11   2040   104.5   10.54   44.64
      2.51   2160   119.5   11.56   52.72
      2.91   2240   134.6   13.26   63.11
      3.31   2360   152.6   14.96   74.11
      3.73   2480   169.9   16.32   83.64
      4.13   2640   172.2   17.34   85.72
      4.62   3000   176.7   17.68   102.78
      5.02   3160   177.4   17.68   106.53
      5.42   3200   176.7   17.68   109.75
      5.84   3240   177.4   17.68   110.5
      6.34   3360   181.2   18.02   118.28
      6.74   3520   180.5   18.02   120.11
      7.14   3640   183.5   18.02   127.94
      7.54   3800   185.7   18.02   139.86
      7.95   3960   188   18.36   144.61
      8.35   4040   188   18.36   146.39
      8.85   4160   189.5   18.36   151.64
      9.25   4320   191   18.7   156.69
      9.65   4440   191.7   19.04   165.25
      10.06   4520   191.7   19.38   165.72
      10.46   4600   189.5   19.04   167.25
      10.86   4720   188.7   18.7   176.69
      11.26   4840   191.7   19.38   177.67
      11.66   4960   191.7   19.72   185.89
      12.06   5080   191.7   20.06   192.28
      12.46   5200   191.7   20.4   202.22
      12.88   5320   191.7   20.74   204.81
      13.28   5440   191.7   21.08   210.36
      13.68   5560   191.7   20.4   213.75
      14.08   5680   191.7   20.74   215.97
      14.48   5760   191.7   20.4   219.44
      14.88   5880   191.7   19.38   220.5
      15.28   5960   191.7   19.38   220.14
      15.69   6080   189.5   19.04   219.44
      16.21   6200   189.5   19.04   219.81
      16.7   6280   185   18.36   220.22
      17.2   6400   181.2   18.36   219.44
      17.61   6480   176.7   17.68   222.25
      18.11   6560   175.2   17.68   221.56
      18.61   6640   175.9   18.36   219.36
      19.02   6720   156.4   16.32   197.64
      19.42   6200   11.3   1.36   1.5
      19.92   4880   14.3   1.7   10.22
      20.32   4320   12   0   9.53
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    is that the same car as first log post? airflow gone up to 221?! thats dam good.
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Yeah same car, done a few changes jetex cone filter and n294 by pass thanks to chriscurzon.... also temp was 2.5 c tonight...lol
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    How come your putting regular fuel in you skin flint......lol
    Jetex yet again showing good flow......
    wonder why it is only 1 cylinder with the bad fuel pull?
    May 2010
    I was wondering if it could be plugs too maybe?
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Because i thought it was all b**locks about 99 fuel...lol
    Going to finish this tank and fill with 99 ron and do some more logs if Chris dont mind!!!
    Jetex sure is showing good flow..
    hopefully some one can help me with that one
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Check your inlet mani to see if there is fuel residue around the injector seats, maybe leaking giving you rubbish fuelling in cylinder giving you timing pull on.
    Nathan
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    May 2010
    I'll take a look at that for him you can't smell and fuel under the bonnet though.
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Car will be at home all week just get the keys when you get a min cheers mate..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Have you checked your charge pipes for oil? Had a couple of cars in over the past couple of months that pulled timing like mad and it was due to piston ring wear and/or turbo oil seal... blown turbo oil seal doesn't always blow oil straight out the turbine into clouds of blue smoke... can be drawn into the comp housing and sits at the bottom of the SMIC (the drivers side on in the case of an S3)... this will mist and dilute the fuel by quite a bit causing horrendous timing pull... if you are getting 9's I would drive very carefully until you diagnose the prob... the ECU can only pull 12 degrees...
    The Octavia VRS I saw had fresh oil pouring from the throttle body, on the S3 it was pouring out the top charge pipe...
    <tuffty/>
    May 2010
    I'll check the charge pipe see how that looks we had a look at the throttle bodie and that was clean not a drop of oil in it.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by chriscurzon View Post
    check the bottom hose coming out of the drivers side SMIC... its the one that joins the bottom outlet of the SMIC to the pipe that goes across the front of the car.... if there is a lot of oil in there then that should be an indication of whats going on... if it pours out then you have a bigger prob
    <tuffty/>
    May 2010
    Took the pipes off the charge pipe and off the SMIC and there was no oil in there. Was a bit of residue but nothing major. Looked at the injectors and injector seats and around injector 1 it had a bit of residue round it but don't know if it was fuel or oil as it's next to the oil filler
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I had a look at the injector seats whilst you were on vag com Chris, they looked ok to me to be honest
    May 2010
    Thought they looked okay am sure it's just the crap fuel luke's running lol
  28. #27
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Now now just half a tank to go then good fuel!!!! lol and more runs!!!
  29. #28
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Must be
    Should be pretty good once it get some proper food lol
  30. #29
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Lets hope so!!!
