AH FabricationsVolks Autos
Results 1 to 7 of 7
    AudiiduA's Avatar
    Midlands
    358
    Intereior lights not going out!
    Hi all. i noticed the interior lights arnt going out and the info panel says drivers door still open! seems to be much worse the hotter the weather! anyone had a similar prob?
    Cheers fellas
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,626
    microswitch on the door....I had it and you might also experiance the three beeps from your alarm in the morning because its doing overtime
    AudiiduA's Avatar
    Midlands
    358
    Quote Originally Posted by voorhees View Post
    Cheers for that! but where is it located as i have looked and cant find anything????? usually a button or summat!!!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,641
    Do a search mate, there is a full write up on here somewhere, I used it and so have a few others and it works a treat, basically, you need a wire hanger and need to have a feel around in the locking mechanism on the side of the door, you can tell you are touching it as the light on the inside of the door will go on and off when you make contact, it just needs a tug to sort it.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,076
    Mine old one does this too, in Really hot weather it wouldn't recognise the drivers door being shut.
    As a result, your alarm also won't arm when you lock the car....
    Most annoying
    Aug 2007
    199
    My S3 used to do this all the time and very rarely now since I poked the microswitch with a coat hanger wire and lagged the switch in Molyslip spray. If it does 'stick', a normal (none forceful) door open-shut usually cures it.
    AudiiduA's Avatar
    Midlands
    358
    Cheers all! off to find a coat hanger lol
