Results 1 to 16 of 16
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    How do you test the DV?
    I have an irratic boost, and wondered if it was my standard DV on its way out!
    How can you test if its faulty, i have read a few links but still un-sure.
    It's better to burn up, than to fade away...
    Aug 2009
    Gosport, Hants
    367
    Remove it from the car, push your finger up the bottom port, pushing the diaphragm up against the spring pressure, then put your palm over the side port of it creating a seal and release your finger on the diaphragm. The diaphragm should stay up against the spring pressure until you release the seal on the side port. If not then your DV is passing.
    2003 Dolphin Grey S3, with a few mods....
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Low Boost – Limp Mode, MBC, BOV, DV, Boost Leak, N75,
    High Boost – MBC Setting, N75, Spark Plugs, Ignition Coils
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Cheers. will try that tomorrow.
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Quote Originally Posted by OllieH View Post
    Shouldnt you put your fingers over the vacuum hole on the top, not the side port.
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    Aug 2009
    Gosport, Hants
    367
    Quote Originally Posted by S3 Nattie View Post
    Yep, think you're right. My bad
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    I Remove it from my car today, pushed my finger up the bottom port, pushing the diaphragm up against the spring pressure, then put my palm over the side port of it creating a seal and released my finger from the diaphragm. The diaphragm just released, i also tried the top but that also just released.
    Does this mean my DV is knacked?
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Sounds like it, time for a Forge 007p methinks, better design, but costs about 70, as oppposed to about 20 or so for a standard Bosch DV
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Aug 2009
    Gosport, Hants
    367
    My bad for saying the side port, it was the small nipple on top that the 4mm pipe attaches to, but if that didn't work either then your DV isn't working and you need to replace it. Standard Bosch is ok if the car is standard and you plan to keep it that way, if not I would go with the Forge 007P.
    Sep 2009
    Essex
    2,366
    pull it off. blow down both ends, and the vac hose. should all be air tight
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    If i blow through the side pipe air comes easily through the top vacuum pipe. If i blow through the top vacuum pipe, air easily passes through the side hole.
    If i blow through the bottom pipe, air will not pass through.
    Can anyone tell me if this is the correct function?
    Sep 2009
    Essex
    2,366
    is code F
    bottom part should be air tight. vac line should be air tight. side should be air tight unless vac is applied to the vac pipe
    time for a new DV, get on the blower to audi or vw
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Testing DV is simple and has been said already.
    Push the diaphragm up with a finger or pen to compress the spring, then place you finger over the top nipple (vacuum) then release your finger or pen from under the diaphragm and it should stay in position (compressing the spring)
    If it goes down then diaphragm is split and you need a new one
    Nathan
    For sale
    PM for info.
    Sep 2009
    Essex
    2,366
    that would test the diaphragm, but there is also a seal in the plunger too. ive got a spare at home, i might dissect it
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Replaced my DV with a Forge 007p today. Definately worth every penny.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    slight improvement but still over priced if you ask me :/
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
