EM TuningChris Nott
    Oct 2007
    42
    rear wheels locking during 3 point turns.?
    hello can anybody help , when ever i perform 3 point turns or turn out of a junction my rear wheels lock up.Also the rear is really twichy when ever i hit bumps .i did have a snaped spring which i thought was the problem but it wasnt .i was reading a post about this a while ago and i dont no if any 1 got the problem sorted .any help will be much appreciated.
    thanks .
    May 2009
    19
    Hi mate
    Have you scanned your car on VAGCOM? Does the traction light come when this happens (Circle, triangle and ! symbol)?? I had the same problem and it turned out to be a faulty wheel speed sensor (ABS)...
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    yep, your best bet is to use vagcom initially and if your lucky it will pin point the problem. what year is your s3 ?
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    mikes3's Avatar
    Mar 2010
    Chester
    Id have a bet the problem is your tyres.
    If you have some excessive wear on the insides of your front tyres the same problem will occur. You might find it ok in a straight line, but a problem when the wheels are on full lock. As I have found out by my own experience, its vital for the 4WD system that all of the tyres are within a certain diameter of each other for everything to work fine. 2 or 3mm difference in tread can cause the problems your facing.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    I hope its not a dead/dying Diff/Haldex... Some people have got lucky with oil and filter changes on the Haldex unit, or using a known good controller to prove it.
    I would start with the Haldex oil and filter ( sub 50) for parts and go from there
