Volks AutosChris Nott
Results 1 to 12 of 12
    MTM S3, Aprilia RSV Mille
    Ringwood
    110
    Bad week for the S3
    Evening all. First problem was at the start of the week, my engine light has come up, no idea as to what is causing this as I don't have VAGCOM and the car feels absolutely fine, not sure if its something silly, is there anyway of resetting the light with out VAGCOM to see if its something silly that won't bring up the light again?
    Problem 2 driving to work this morning, left my house with half a tank arrived to work with a full tank and got back home showing 3/4 of a tank, what is going on there?
    Many thanks
    Chris
    S3 MTM
    RX8 - Thankfully gone
    Corolla T Sport - Gone
    Celica GT4 ST205 - Gone
    Clio 172 - Gone
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    vagcom scan or 50 at Audi to fault find
    http://maps.google.com/maps/ms?hl=en...,26.784668&z=6
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Aug 2009
    Gosport, Hants
    367
    Disconnect the battery for 10 mins will reset the ecu, however you will need to re enter the stereo code afterwards, and reconfigure the auto window up/down function. (Both easily done, just so you're aware.)
    No idea on the tank contents problem.
    I have vagcom in Gosport if that's any good to you, not far from Ringwood.
    2003 Dolphin Grey S3, with a few mods....
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    I'd be getting a scan done if I were you - engine light could indicate a serious issue and you should not be driving the car without knowing what is wrong. Just resetting the light will not fix whatever caused it in the first place.
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    on second thought - engine light, increased fuel consumption.... lambda sensor grew wings and went to lambda heaven? just a guess.
    Ringwood
    110
    Fuel consumption is fine, its just the gauge is going up for some reason, could be the fuel sender unit, would that trigger the engine light to come on? Only thing is the light came on a few days before this problem.
    S3 MTM
    Clio 172 - Gone
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    Like I said - the only sure way to diagnose this is with VCDS (vagcom). sorry
    Ringwood
    110
    Quote Originally Posted by leshkin View Post
    Will these cheapy 10 VAGCOM's off ebay diagnose and clear any faults?
    S3 MTM
    Clio 172 - Gone
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    works for some and does not for others
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    Aug 2009
    Gosport, Hants
    367
    Quote Originally Posted by chris_marshall View Post
    I think you can read and clear faults, but can't datalog anything. It tells you on the rosstech site somewhere I think.
    Edit: http://www.ross-tech.com/vag-com/vag-functions.html
    Ringwood
    110
    Quote Originally Posted by OllieH View Post
    Yeah, I really couldnt give two hoots about logging stuff, just want something that will tell me the fault,so I can get the part, then clear the engine light
    S3 MTM
    Clio 172 - Gone
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    The e-bay cable should be fine, but you will most likely have to buy the $99 worth of VCDS, as the error code reading function on a shareware version will show you only some of the codes IIRC.
    An alternative is to get one of the local members with the cable to help you, which might be completely free.
