Sky InsuranceVolks Autos
    May 2010
    35
    Water temperature and boost pressure
    Hi guys. Im quite new to the Audi scene and just had a quick question about my water temperature gauge and boost presure. I have a 1.8t with an AGU engine. I have noticed that the car gets to 90 degrees very quickly. It never passes 90, so i assume its not a problem but I was just wondering if this is normal for these engines?
    Secondly I fitted a boost gauge and found that it is boosting at round 14psi. Is this standard boost or has the boost been upped?
    Cheers Adam
    Chugger
    North Devon
    2,716
    well they are cheaky and have varible gauges, basically means anywhere between 80 and 105 (or something like that) the gauge will sit at 90. Its basically to make the car look 'quality' and stop people going into dealers worrying about the temperture of the engine.
    14 psi is about right for a mapped A3 i think
    57 A3 2.0 TDI Sportback (140)
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    That's fine, as long as it stays only at 90, no more no less
    8 psi is normal I think... I am sure someone will correct if I am wrong
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    May 2010
    35
    It doesnt pass 90 it was just the fact it gets up to temperature in about 5 minutes that puzzled me a bit.
    Sound that's saved money on the map then!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    8 PSI is standard boost.
    Yours has most likely been mapped for the boost to be that high.
    Homer Simpson
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    for sure, mapped
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
