Badger5Chris Nott
Results 1 to 19 of 19
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Removing central locking pump
    Hi,my central locking pump is fooked so i need to get it out to have a look at it and part numbers etc.is there a guide on how to remove the pump and check if its ok??..
    A3 1.8 TURBO| RS6 18INCH ALLOYS | FORGE 007 | SMOOTHED O/E BOX WITH COLD AIR FEED | COILOVERS | MOTECH RE-MAP | FULL CREAM LEATHER | FORGE DV RELOCATION | FORGE TIP HOSE|SILICONE BOOST HOSES|REMOVED REAR WIPER|G60 FLYWHEEL & VR6 CLUCTH|MILTEK CAT BACK DISCREET SYSTEM|312MM BRAKE UPGRADE|UPRATED DOG BONE MOUNT.
    Jun 2003
    World of my own
    9,813
    It's just secured with a big zip tie, but you have to take the boot panel out to get to it.
    Alex Turner
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    oh right.ive had a quick look and looks like i will have to remove the sub box to??..or taking the whole boot panel out i wont have to remove the sub?..
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    would like to know too
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Me 3
    2001 AMK ...Black
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Bump!!....someone must of taken there pump out and either tested or fixed it hmmm???.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Like Andy said the best way in is by moving the boot trim out the way. If you remove the screws under the boot net fixings and remove the plastic trim around the lock mech. If i remember correctly there are 2 more screws inside the cubby hole where the pump lives. You should then be able to tug very hard on the trim around the pump and it should all unclip and pull away giving you more room to move.
    What symptoms you got with the pump steve?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Well the central locking has stopped mate but i can still hear the pump working away in the boot when i open the car etc,so i reckon its the pump.Is there a way of testing the pump once i have got it out mate?
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    error I got was
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    Sounds loud and runs for a while
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    Westy's Avatar
    Dec 2008
    17,273
    The usual thing that goes is the internals shear off and leave you needing a recon kit to fix it. When you get it out open it up and see if the motor cogs have packed in. You can buy the recon kits off ebay for quite cheap. If you dont fancy doing it yourself drop "olds_kool" a PM as he does reconditioned pumps and takes yours as a replacement for about 60.
    S3 Build Thread
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    lol how do I lock the car after I have removed it for a swap, don't have a garage
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Quote Originally Posted by finesse View Post
    Just use the key, simples. Remote locking wont work but the locks still can be operated with the key like the old days.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    thanks sportsquattro
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Yep ive just removed my pump and i will open it up and have a look later.quiet an easy job really.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Quote Originally Posted by steviet View Post
    Any chance of pictures/guide?
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    No pics mate but a quick guide.
    1st thing i did was take out the boot floor.Then i removed three rope eyes,one to the left and the other two towards the bumper.You have to remove these two so you can take out the plastic strip which is held in by torx screws.This is the strip to the rear that goes over the boot lock.
    Remove the cover to the sub etc and if you look up inside there is a plastic black screw which has to be removed.Push down the rear seats and there should be a rubber type of screw next to the seat lock hoop if you get me.once these have been removed you just need to give it a good pull!!...then just clip the cable tie on the pump and disconect the pipes and socket.
    hope this helps,im not to good at explaning things.i should of taken some photos!.
    Aug 2009
    Gosport, Hants
    367
    error I got was
    I'm getting this aswell. Will have to take a look at some time...
    2003 Dolphin Grey S3, with a few mods....
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Quote Originally Posted by OllieH View Post
    Another job for you to do Ollie
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    Aug 2009
    Gosport, Hants
    367
    lol, tell me about it
