    Aug 2009
    Cheltenham
    333
    Hesitant Under Acceleration
    Hello,
    I got home from work today and thought I would add a cold air feed to the original airbox. So reomved the airbox, battery and battery box and proceeded to route my new 3.5" ducting.
    I had to move the loom from under the battery box and the 2 earth wires. It was a bit of squeeze but I managed to route it from the air box down the side of the battery, under the headlight passsed the intercooler return and set opening of the ducting next to the fog light.
    The looms required a bit of easing to enable them to be resecured but no major 'tugging' of the wires. I refitted the earth terminals, battery box, battery and then air box.
    Pleased with my new ducting I decided to go for a bit of a drive....
    Now under acceleration it seems like it is misfiring, really hesitant... I quickly plumbed in the original air feed but it is still the same..
    I didn't have a chance to give it a boot before I started the work, but It would be a bit of coincidece that a coilpack or some thing also gone down.
    Any ideas or pointers??? Any info much appreciated..
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,845
    Sounds like a knackered MAF symptoms, try disconnecting it and see if it still splutters.
    You've got to have a laugh!
    Aug 2009
    Cheltenham
    333
    Will do, I should be able to see that in vagcom???
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,845
    Quote Originally Posted by Barks View Post
    Not always, it will probably show it as intermittent if it does flag up.
