My car has recently started to hesitate when cold. Its most noticable when leaving my works car park as they have a 20mph limit. Sitting around 20mph the engine starts hesitating, easiest way to describe it is as if im lifting on and off the throttle a little bit.
Once the engine is warm the problem goes away but it can be abit lumpy at idle.
Had a garage run a diagnostics but they did not find any fault codes and said come back in a few weeks when the issues gets worse.
Do any of you guys have any ideas what it could be causing the problem?
Cheers,
Chris
Cheers,
Chris
