AH FabricationsVolks Autos
Results 1 to 16 of 16
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    Chesterfield, Derbyshire, United Kingdom
    612
    Question 1.8t induction problem
    Hi i fitted a apexi cone induction kit yesterday, i did 50 mile in it last night and all was well but today i did about 10 mile and the car started juddering at low speed with foot slightly on accelerator, it did it a few times. i went home and had a look around and i couldnt see anything a miss. so tonight i went out and after about 25 mile it started it again. the car pulls well accelerates fine. just wondering if it maybe because it has been realy hot today and my new filter is sucking to much hot air.
    please let me no you'r thoughts maybe someone has had a simmular problem with these cone filters.
    Many thanks
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    Is your ignition amp being keeped cool?
    Now to many mods to list! Lots of power, torque and Leather!
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    hi yes. were the pipe goes to the inner wing it fitted perfect in that so thats were it is. i had a feel and it wasnt hot at all
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    would this cause that problem ive described. were do you all put your's
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    your ignition amp is in your inner wing? mine will only reach to where the bottom of the air box was. i have mine under a heat shield that has its own cold air feed running to it. the hot weather will effect the performance slightly but not major. 1st time its been hot since i fitted my induction kit and was saying only today how good the cars pulling still in hot weather.
    my moneys on your ignition amp not working correctly. get it on VAG-COM dude
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    ok cheers, i will mount it on a bigger heat sink in the engine bay some were. the original coll air feed pipe is were it is at the minute
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    mines just cable tied around the intake pipe on my carbonio. Works fine.
    Did u knock it about a bit by any chance whilst fitting your induction? they can be quite sensative.
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Chugger
    North Devon
    2,716
    did you disconnect maf at all? could be a connection on that which is failing. Try cleaning that up, and clamping the plug to the maf with cable ties
    57 A3 2.0 TDI Sportback (140)
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Bit more info for you:
    The 'Ignition amp' is infact called the Final Power Output Stage Module.
    They ONLY come on the AGU engine in A3s. If you have any other engine, you won't have one.
    Part number for the AGU is 4D0 905 351 (also available is the 8D0 905 351 - you don't want one of these).
    As Alpine said - normally fitted to the air box for cooling, as they do get quite warm.
    I would get it on VAG COM before starting swapping bits over, trial and error style. That can get expensive, when VC may just tell you what the problem is.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    The odd thing about the fault is that it only starts happening after a substantial period of driving! I hate problems like that as they are so hard to replicate!
    Homer Simpson
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Homer Simpson
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    The ignition amp is the same for the AGU and the AEB despite the differeing part numbers. FWIW
    They do tend to drop cyl 2 first upon faiure
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Byzan A4 View Post
    Mark, why didn't you tell me this before? LOL. I even asked Audi and they said I had to have the 4 not the 8, I spent about 3 months trying to find one for testing because I wasn't sure if that was the problem.
    LOL. Oh well.
    Homer Simpson
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    ok thanks for all you'r replys i have have since moved the the ignition amp to a cooler place and only just gets a little worm. but after a hours driving it started to do it again. this is very odd. i would much rather it be doing it all the time it would be definitely easier to diagnose. i carn't understand why it only does it after like 20+ miles - its like there is a loose connection or something but ive checked the connections not only that you would think it would do it weather ive done 1 mile or 50 mile. it is only doing it when the car is hot ???
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    i have just been and pulled my airfilter off and i noticed a bit of oil on the inside of my pipes. when i put my new filter on i put the tiniest bit of baby oil on to slide the pipes on. im just wondering when the engine bay is getting hot its thining the oil off and sucking in to the inlet causing my kangaroo a3. what do you all reckon.
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    btt
